Question about Gaggia Coffee Makers & Espresso Machines
Gaggia Brera - dregs tray will not go back into the slot. How do I resolve this? Thanks
JohnnyBeans
  • 223 Answers
SOURCE: Unable to replace dreg box
If you look to the left side of where the dump box slides in you will see a opening in the case. This is the dump box switch. use a knife to hold the switch and turn the machine back on.
This will reset the machine to it proper position. I would recommend cleaking your machine so this doesnt happen.
http://cerinicoffee.com/clean_descale_coffee_equipment_instructions.asp
Posted on Oct 12, 2007
SOURCE: Tray and Dregs light flash when machine turns on
Yes, I had similar problem (still do) because after a few years the heater element had slightly warped the left side of the dreg drawer, so the tab no longer actuates the micro switch unless you insert it very carefully. I'm the only one in the office who has the "Magic" (ahem) touch, everyone else goes raving nuts when they can't get the light to go out.
Posted on Jan 19, 2008
EsWorld
  • 1618 Answers
SOURCE: I have a gaggia syncrony
The coffee grind could be too fine and or not enough coffee is being added to the brew chamber after the machine grinds it. You can try to adjust the amount of coffee being used for an espresso and or adjust the grind.
Posted on May 20, 2011
  • 51 Answers
SOURCE: i have gaggia brera and after brewing a cup the
Try to descale your machine, use descaling tablets or descaling powder.
Posted on Jul 16, 2011
hendriks_edw
SOURCE: gaggia brera brew group wont go back in
If you close the machine without the brew unit inside, the gears aren't aligned anymore. I tried to put the machine off and then back on. You can hear the gears turn. After a couple of repeats, I was able to put the brew unit back inside.
Posted on Jun 26, 2012
GAGGIA Brera RI9833/61 - Descaling light still on after descaling
I think that you button doesn't make a good contact. Try to press it with different pressure and on different sides slightly off center to give this a try - it may be just a bad contact that is enough to change the bean setting but not enough to reset the warning indicator through a long press. Let me know how it goes ... they may have changed the button that needs to be pressed as well (does your manual say anything different?)
Mar 05, 2016 | Gaggia Brera Coffee Maker
My Gaggia Brera has all four warning lights blinking simultaneously. And won't make any coffee. Ideas?
hi,when you have the warning lights blinking it may you have a faulty micro switches you have one for the brewer one for the door and one for the basket or faulty boiler not heating up
Oct 13, 2014 | Gaggia Brera Coffee Maker
Gaggia brera descale stays on
try to hold the steam/hotwater button for 5-6 seconds.
Aug 15, 2014 | Gaggia Brera Coffee Maker
Gaggia brera brew group wont go back in
May 13, 2012 | Gaggia Brera Coffee Maker
Brera: coffee grounds inside + internal leak
finer grind setting and non oily beans did the trick for me.......
Apr 17, 2012 | Gaggia Brera Coffee Maker
I have a gaggia syncrony logic that has just come back from the repairers.! The coffee dregs are almost liquid whereas before they were solid patties & liquid is found in the drip tray after every...
May 20, 2011 | Gaggia Syncrony Logic 74884 Espresso...
Dregdrawer full
Check the back of the drain tray make sure there are no grinds. Then we will have to test the micro switches, remove the drain tray and dregs drawer, insert tray without the drawer, to see if you get an error. A more complicated way is to have the door open place tray minus drawer in machine, then using a small stray or plastic knife, activate the microswitches.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
Dredge drawer high level not working. Tray overflows
The only indicator for the dreg tray is the orange float.
If you can see it poking up it's full.
There is no electronic indicator for this.
Feb 20, 2010 | Gaggia Titanium Espresso Machine
Red Light 28 is flashing even when dregs are emptied
Check the edge of the container that goes in to the machine there is a small part that sticks out, it is possible that that piece is not touching the microswitch in the machine. Remove the drain tray and the dregs tray, check the corners of the machine for loose coffee grounds.
May 31, 2009 | Gaggia Syncrony Compact Coffee...
Coffee Makers & Espresso Machines Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
