JBL MCDC100 6-Disc CD Changer Logo
Posted on Apr 01, 2009
Tape player stopped working- spits out tape
I have a 2005 toyota 4-runner and I used the tape player to play my Sirius radio for the past two years. Today, the tape player would flip to the other side of the tape (it has never worked on that side) and try to play for a few seconds. It would eventually spit the tape out. Any suggestions so I don't have to replace the head unit? Its a JBL 6-disc toyota factory reciever with tape deck
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
785
Points
I have the same problem. Any luck?
I own a 1997 Ford Taurus. I am trying to use a tape to mp3 player adapter in its tape player. When I push the tape in the player, I get a "TDE3" message and the tape spits out. I tried using another tape,...
It's the tape deck there must be a tape that got caught inside and is wrapped around the capstan or the heads and the radio stays on because the switch is not activated by the deck lowering down far enough you have to take it out and clean it and look for any tape or other obstructions that would stop the mechanism from working including the belt you may need parts and a 20 year old radio there hard to find try the junk yard for a replacement but you can operate yours with the cover off if you can get it out far enough to see inside while it's on and that will help you find the problem but first bring it inside your house so you don't loose parts after cleaning with alcohol and derusting if any and a light lubricant you might be lucky see what happens I also use an adapter for my cell phone music in a 2007 bull and I also did it in an 87 bull with a cd player so I know what your talking about also make sure the adapter wire is not hanging up when pushing it in good luck also brand new replacements might be the best way to get the music you want they have auxiliary input jacks for cell phone mp3 players but try to fix yours first the learning part is priceless for the future radios you will own
Unit keeps beeping and turning itself on and off. Have had this radio for 5 years and never a problem until now.
Hi sasutton,
SIRIUS-Ready radios are usually identified by the SIRIUS dog symbol appearing somewhere on the radio itself. A SIRIUS-Ready radio is a radio that may require the purchase of a SIRIUS tuner in order to be activated.
Every 90 minutes if you do not interact with the player, player display a notice and play a small audible alert to ask if you're still listening to the player. If you're not, the player will shut down after five minutes of the message being up there. If you are there, all you have to do is click the button and you can continue listening. Sirius player do this so that we're not streaming to computers that have no listeners, to maintain optimum performance for active listeners. You are probably not sitting at your computer when this message pops open which is why you get interrupted.
And Thanks.
Please help me, I have a 4 Runner 2003 that has a JBL CD Player and a Cassett player in one built in the dash. Both are not working: The CD Player keeps flashing (Error 3) when ever I put a CD in...
did the error code start with the tape getting stuck? i have heard that if you disconnect the battery for 5-10 minutes it will reset the radio but make sure you have a code for it to unlock it it the radio has security. they say it starts working again if you do this. again this is just what i have heard a toyota tech say when i worked there. it may be that it knows it has a problem with the tape and keeps it inop, as far as getting the tape out, it either breaks the tape or the tape player or both. i worked at a car stereo shop for 10 years and very rare for both to survive.
1helpful
My cd will not go into the cd player. It usually just slides in, but now it won't. Then when I give it a little shove, it won't come back out. I had to get a butter knife and a piece of packaging tape and...
My cd player had stopped playing my burnt CD and the dealer ship just replaced it. But then it happend again and I was ridding just listening to the radio for about 3-4months, VERY BAD, until I just took out the fuse for a few minutes and that just reset the radio and spit the cd back out. This may work for you.
IT PLAYS TAPES SLOW
can i buy your panasonic rx-dt75. i have that model almost 15 yrs to me made in japan. but this past few months cd and tape do not work... contact me here +639392859269
1helpful
2answers
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Sirius Tuner
Any Radio will work with Sirius if you use the FM feature and tune your radio to 107.1
2answers
FM Modulator
I haven't found any ways that work. A better option is to use this device http://www.xm-sirius-satellite-radio.com/SIRIUS_FM_Direct_Adapter_p/fmda25.htm to make a direct connection into your radio's antenna plug. This adapter allows your satellite radio to provide clear, static-free sound. It can be difficult to install, however, depending on how hard it is to get to the back of your vehicle's radio.
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
John
John
 Mikey
Mikey
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
