Question about Sewing Machines
Singer serenade 10
Fine fabrics slip and stitch is too loose
bargainbox
  • 1388 Answers
SOURCE: bobbin tension
This is an issue of your upper thread tension, so take a look at this generic tension solution
If you are in a pickle with your bobbin case, check top tension and bobbin case are free of lint, reset the top tension to 4, and adjust the bobbin tension to suit......some more detail on how to do that, is here
Bargain Box
Posted on Jan 30, 2008
SOURCE: BOTTOM STITCH IS ALWAYS LOOSE
my top thread is pulling thru to the underside..looks like little birds feet tracks on the back of the quilt...help
Posted on Aug 09, 2008
  • 69 Answers
SOURCE: singer 301A stitch jam
It sounds like your feed pressure and tension are both off. Try sewing with out thread. If the fabric goes all over the place, you need to adjust the feed pressure (the screw on the top of the machine). Tighten it down until your fabric feeds evenly. If the fabric is bogging and not feeding, you need to loosen it.
Your tension sounds like it is off as well. Make sure it is set around 2-3 and check your tension disc, make sure there is no thread in between the disc. If so, remove it. Now, thread the machine and check the thread through the needle. It should pull out quickly and smoothly. Now, put the presser foot in the down position and pull the thread, it should have some resistance. If not, your tension is set too low. Turn it up a little and try sewing. If the thread is still knotting up, you can turn the tension up to about 5, if that does not correct the problem, you will need to adjust the tension dial itself. To do this, press on the numbered part of the dial and it will push in, then turn it to a lower number, release and make sure it has locked back into place. Then adjust again as I previously instructed.
Posted on Feb 07, 2009
  • 6 Answers
SOURCE: when making a straight stitch or Zigzag stitch,
Your top tensioner is too loose.make sure the thread runs through all the relevant eyes and then tighten the top tension little by little as you do a sample few stitches.
Posted on Feb 21, 2009
bargainbox
  • 1388 Answers
SOURCE: singer 237 stitches loose on bottom of fabric
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Sep 02, 2009
I HAVE A SINGER MERRIT 8734 AND NEED TO KNOW WHAT THE NORMAL STITCH SETTING IS.
"Normal" is difficult to describe because it depends on the thread and fabric you are stitching. Standard straight stitch setting for most standard fabrics is probably whatever will deliver 10-12 stitches per inch.
Feb 05, 2017 | Singer Sewing Machines
Singer 2112
first ,re thread the upper bobbin, check the needle to match the fabric and the lower bobbin thread should be the same like the upper thread. If it dose not work, clean the discs tension for the upper thread.
Aug 15, 2014 | Singer Sewing Machines
My singer 4830C sewing machine won't make stitches. It runs the thread across the fabric but isn't catching
Clean the bottom. The place that nail going into it. You can use Vaccume too.
Dec 15, 2013 | Singer 4830
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
normal
here is a free manual
http://www.singerco.com/uploads/download/696_5417c.pdf
Jan 07, 2013 | Singer 5417 Mechanical Sewing Machine
Loose bottom stitches on Singer 1507
top tension must be adjusted to fix loose stitches of bottom stitches
adust the top tension one letter or number higher and sew on a scrap
piece of fabric till stitches look correct,, here is a free manual
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
Jan 06, 2013 | Singer 1507
I have the singer 7442 and i cannot figure out how to get the baste stitch for gathering material on a flower girls dress. I've tried everything and there's nothing in the manual, can you help with this?...
Normally to gather fabric, you select the regular straight stitch, turn the stitch length up to maximum (4 or 5 usually), and stitch two rows of stitches, one at 10mm from edge and one at 20mm from edge.
Then gather by pulling the bobbin threads (underneath ones) from each end to gather the fabric. If doing lengths of more than 1 metre, then stop, leave long thread tails, and start a fresh length of gathering threads to avoid gathering long lengths of thread which might break on you.
If your machine has a basting stitch it might look like " .___.___.___" on the dial however, I've never been that happy with machine basting for things like attaching slippery fabric to underlining, I've always done it with needle and thread to keep the two layers matching and not stretching/slipping. For example, stitching a piece of chiffon to a underlayer of satin, even pinning carefully, these two fabrics will slip under the machine foot so I'd always do it by hand.
If you have masses of fabric to gather, sometimes what is quicker is doing a large wide zig zag over a length of perle cotton (heavier than thread) at the 15mm seam, don't let the needle pierce the cotton though. Then you can gather the fabric along the perle cotton.
Sewing machine instruction manual often assumes a knowledge of sewing techniques that you may not yet have. I have the Vogue Book of Sewing on my shelf and refer to it often. Or Singer do a good range of sewing books too, its worth investing in a good reference book.
I also love www.patternreview.com, this is such an awesome website for dressmakers/sewing enthusiasts and you will find loads of helpful tips here.
Hope this helps you a little.
Apr 16, 2011 | Singer 7422
My bobbin stitch is loose. I have tried adjusting tension and have changed the needle.
A. To correct loose stitches, try the following: (1) Balance the thread tension. If the stitches are loose on top of the fabric, decrease the tension to the next lower number. If they are loose on the underside set the tension to the next higher number. (2) Make sure the needle/upper thread follows the threading path. (3) Check to see that the bobbin case is threaded properly. (4) Use a different size needle. For fine fabrics, use a smaller needle (size 9, 11); medium-weight fabrics require a size 14 or 16. And use a size 18 or "Denim" needle for heavy corduroy or denim.
Sep 20, 2010 | Singer Curvy 8770 Electronic Sewing...
Stitches are on the reverse of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
thank's
Apr 09, 2009 | Singer 7444 Mechanical Sewing Machine
Sewing Machines Logo
19 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
