Question about Hayward Phantom Pool Cleaner Complete with Booster Pump
Need to get plastic pieces apart to replace a piece whaat is the easiest way
Replacing mirror
On GM cars their is usually a small triangle plastic piece above the panel in the front of the door. remove screw and plastic piece. then look for 3 10MM nuts. Undue and pull off mirror.
Jan 05, 2014 | Oldsmobile Cars & Trucks
Replace keyboard on acer 8100 series laptop
Replace the inside of the keyboard with a new piece. One of the major problems with Dell keyboards is that the plastic pieces holding the keys in place become loose or broken. You can find a cheap keyboard from Papatek.com or an electronics store. Simply take apart the new keyboard, pull the keys off your keyboard, lay the plastic piece on top and replace your keys.
http://www.papatek.com/Acer-Keyboard/Acer-Travelmate-8100-keyboard.html
Jul 23, 2010 | Acer Ferrari 4000 Notebook
REPLACING KEYBOARD OF A ACER 3002 LCI LAPTOP
Replace the inside of the keyboard with a new piece. One of the major problems with Acer keyboards is that the plastic pieces holding the keys in place become loose or broken. You can find a cheap keyboard from Papatek.com or an electronics store. Simply take apart the new keyboard, pull the keys off your keyboard, lay the plastic piece on top and replace your keys.
Jul 01, 2010 | Acer Aspire 3002LCi Notebook
I cant get my window down. I took it apart plastic piece that hold window up is broke. How do I get window down to replace plastic piece
sounds like window is leaning. you might have to physically hold window in alignment then try putting it down. if not remove the other plastic piece and take window out, replace window mounts and put window back in.
Oct 19, 2009 | 2000 Oldsmobile Alero
Will not agitate. motor runs, no swish
Assuming that this is the basic Kenmore / Whirlpool top load, direct drive, neutral drain two piece agitator model.
There is a Sears repair parts site:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and a list of major sub-components will come up.
Since it isn't agitating (I assume not at all rather than just the top part of the agitator. If just the top part isn't turning then the easiest solution is replacing the 4 "agitator dogs" ) the solution points to a couple of places.
1. The motor coupler may be broken.
This piece is a fail safe between the motor and transmission. and basically transmits power to the transmission.
This is a relatively easy fix for the basic Kenmore / Whirlpool washers.
http://www.fixya.com/support/r699497-replacing_gearcase
Follow the instructions for removing the cabinet and pulling the pump, motor and motor mounting plate.
The coupler has two plastic pieces with three prongs each. In between is the rubber coupler with six holes. If either of the plastic pieces or the rubber coupler are damaged,
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Sep 29, 2009 | Kenmore 22422 Top Load Washer
Whirlpool Clutch Problem
H i there.........it sounds as if your incorrectly assembling the clutch ....there is a diagram with the new clutch....no its part of the assembly
regards Sir Galahad
Aug 20, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Cracked case
Hi there.
You can order spare parts from Acer themselves or alternatively look on Ebay for spare plastics.
It sounds like you need the lid face and bezel (plastic that surrounds the screen), as for disassembley i'm afraid its trial and error as you may have to take the laptop apart to replace the plastics.
Good luck and thanks for using FixYa!!
Mar 04, 2009 | Acer Aspire 3680 Notebook
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kodak EasyShare Z612 Digital Eye piece
you have to take off the back plastic part of the camera carefully. I snapped it off carefully. Then you take off 2 black screws at the eye piece and insert the rubber. screw back together. snap plastic back on and screw in all the screws. have fun!
Jan 09, 2008 | Kodak EasyShare Z612 Digital Camera
Hayward Phantom Pool Cleaner Complete with Booster Pump Logo
27 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
