Ibico IL 12 laminate jam. How do I open it to remove the jam?
3 Suggested Answers
SOURCE: ibico 2700 wide roll laminator
Mechanic service code number
Posted on Feb 12, 2008
SOURCE: ibico 2700 laminator
I need to replace the rollers on my IBICO 2700 laminator. I will need to order the new rollers can you help?
Posted on May 29, 2008
My document has jammed inside the laminator. How do I remove the jammed document?
it is not possible to give advice or answers when you simply make unrelated statements...
Oct 27, 2014 | Gbc Creative 9 Laminator
User manual for ibico pl-330 ic
http://office.manualsonline.com/support/other/laminator/laminator-manual-required-2292677
Oct 12, 2014 | Office Equipment & Supplies
Mon lamineuse marque erreur 02. que signifie ce code
Il faut lire le manuel d'utilisation qui e`tait dans la boi^te de ta laminueuse.
Oct 03, 2013 | Ledco Educator 25" School Laminator - Open...
I have a scotch brand laminator tl901- it is jammed...and making a clicking noise...is there a way to open the system and try to unjam it?
First, make sure that the unit is unplugged and has sufficient time to cool off. Then remove six screws on the bottom of the laminator. The screw driver shaft must be thin enough to fit into the holes where the screws are located. Two are very easy to find -- one on each side in deep holes. The other four are hidden under small black rubber disks that the laminator rests on. peel up the rubber disks and remove the rest of the screws. At this point it is easy to remove the cover and remove the jam. To replace the cover you must use a thin tool to pull back the release level so it will fit into its opening in the cover. Replace the six screws and you should be able to ready to laminate again.
Jul 10, 2010 | Office Equipment & Supplies
Hi, Our Ibico IL19VT Laminator (A2) has paper jammed inside of it. There are no reverse mechanisms on the laminator. The only feasible method is to open the laminator up at this point, whether or not...
You can open this yourself but i recommend sending it for repair. If you decide to do it yourself here is how: turn the unit over and on the end with only one screw (not the power setting side) take it out using a Philips screwdriver. Next you will need size 3 and 4 hex bits. Use size 4 to undo the 4 hex screws. Hold the non power end and it should slide off. You will see four rollers two on each side of the heater element. Using the size 3 hex bit undo the 4 hex screws at the exposed end and lift up and out the 2 housing bits. Careful as these are made of plastic and break easy. Remove the offending material and then put everything back together.
Simples!
Aug 21, 2008 | Office Equipment & Supplies
Ibico 2700 laminator
Apr 24, 2008 | Office Equipment & Supplies
Ibico Binding Machine User Manual/Instructions
I found the IbiMaster 400 manual!!! The key was finding out that Ibico was sold to General Binding Corp. (GBC). I went to the GBC web site and it linked me to Acco. I called Acco and they promptly sent me an old, scanned PDF of the manual. The very helpful POC at Acco was:
Kaye.Eldridge@acco.com
Jerry Quinn
Sep 28, 2007 | Office Equipment & Supplies
62 people viewed this question
k24674
