Question about Sharp XE-A402 Electronic Cash Register
How clear E02 ERROR CODE - Sharp XE-A402 Electronic Cash Register
How can I delete E02?
Depends on the make and model but an Error code E02 on most washing machines is slow water flow probably caused by a blocked filter! Remove panel on front bottom left or right side and clean filter! Should then clear error itself!
Oct 21, 2014 | Washing Machines
F06, E02
I think these problems are related to water inlet, take off the hoses from the back of washer and you will find a screen in the outlets clean with old tooth brush until clear.
Feb 19, 2014 | Whirlpool WFW95HEXW Duet 5.0 cu. ft....
Error code F01 E02
For how long did you unplug the power cord? If it was under 5 minutes, unplug it for longer. Check if that clears the error code. If it doesn't, the motor control unit needs to be replaced.
Please double check your model number to get the correct part. Most of the Whirlpool washers have model numbers that start with 3 letters.
I hope this helps.
Dec 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
How the error e02 on fit king treadmill be repaired
Dear sir,
I am having a treadmill of Fitking model no. W590 it is showing error code e02.
Kindly suggest what to do. I am eagerly waiting for ur response
Rgds
Yash Pal
Jul 15, 2013 | Exercise & Fitness
How to solve Error Code E02 always appear
Error Code E02 means paper jam.
Solution
1. Unplug the power cord and USB cable.
2. Lift the printer upside down, then shake the printer.
3. This is done, to remove foreign objects, which get into the roller.
Causes of damage
Solution
Oct 27, 2011 | Office Equipment & Supplies
Error code on Panasonic DP1820E
Sir,checkyour first paper draw ensure paper is properly placed also ensure no paper stuck behind the draw may require removing the draw to clear the paper power off then on the machine to clear the code once paper or what ever is causing the code
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 01, 2010 | Panasonic Workio DP-1820E Copier
DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Apr 23, 2008 | Panasonic Workio DP-1820E Copier
ERROR CODES
In the case the encoder position is not shifted
to the next point though the loading motor has
rotated in the unloading direction for 4 seconds
or more. This error is defined as [E02].
Oct 14, 2007 | JVC GR-AXM17U Camcorder
E02 Code
Faulty heating element, or main eprom is faulty
Jun 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Sharp XE-A402 Electronic Cash Register Logo
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Patrick Tinashe...
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
