Question about Ovens
Instruction manual for Easy Cook benchtop oven 727 Deluxe model
I just bought a about 35year old house it has a chef contessa deluxe gas freestanding oven and warmer i don't know the model no can you help i need a manual and parts
Hello Helen, most model number labels can be found either under the cook-top surface burners; on the side of the oven unit; or in the back near the vent. Other places to consider, behind the oven door jamb along the top or side edges. If your particular stove unit has a kick plate, you may find the oven's schematic attached to the inside of the kick plate with may contain the technical data to your unit. Hope this helps.
Feb 12, 2017 | Ovens
Whirpool Electric Double Oven
1-800-269-2609 call them and they can www.repairclinic.com
Dec 23, 2007 | Ovens
I am very happy with my new smeg oven but no where in the oven manual does it say how to cook puff pastry for example a pie. I have a wall built in oven and have tried turbo and static function
Hello blachett989,
I belive they refer to puf pastry as Fruit Tarts under the sweeties label in the owners manual. As I do not know what model number oven you have I have looked at a few of the owners manuals on line. It states the different types of modes and temperature and approximate cook time for the pastry or tart as they refer to it.
Thank you for choosing FixYa.com if you have anymore questions about this unit I will need a model number to help furthure.
Justin
Mar 10, 2011 | Ovens
Whirlpool Gas Range SF357PEKQ0 -- over heats; will not shut off; have to turn off at gas line behind stove. Error Code: F3E2. Is the replacement part I need the thermostat sensor? Is this part easy enough...
Hi lkanderson97,
This error code F3:E2 means that Oven temperature is too high (Cook mode). The only way to resolve this issue is to replace Oven temperature sensor (RTD). This part can be replaced by your husband. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call. Once you got the part instruction is also provided on how you'll replace the sensor.
Hope this helps.
Thank you for using FixYa.
Nov 22, 2010 | Whirlpool GBS277PDS Electric Single Oven
Delay or time bake
You can find the manual at www.managemyhome.com, and the instruction is on page 11.
You make sure the time is set correctly.
You press Bake, and set the temperature you want to bake.
You press Cook Time and enter the amount of time you want the oven to cook.
You press Delayed Start, and enter the clock time that you want the oven to start.
Jan 30, 2009 | Kenmore 47772/47774/47779 Electric Double...
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
Jenn air oven
I had the same problem. I went to the manual and it is very easy to fix. The oven control lockout was somehow set. To cnacel it just press the Cook Time and the Stop Time buttons at the same time for 4 seconds. The "off' will appear briefly and then disappear. It worked for me. Good Luck!
Aug 20, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
380 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
