Question about Samsung Microwave Ovens
I have Samsung Micro oven Model CE1041DFB. I am using oven from last two years. Since last week i am facing problem, oven shows error E5. Please suggest how to rectify problem ASAP.
3 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: what is a E5 error code in a micro over model
An "SE" error would be a shorted membrane keypad.
I'm not sure about an "E5" error.
You would have to consult the "mini-manual" or technical sheet inside the microwave, usually located behind the control panel or hidden inside the area behind the grille. It may mention an "E5" error.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it is an SE error this is a problem that's pretty easy for the homeowner or a friend to do himself. And you can save $200 or so.
I'll tell you what the DIY options are and you can decide if you'd prefer one of those or to call Sears/Kenmore for service:
Take your control box off as in the video at our site, peel the old keypad off as in this handy guide with pictures , clean the surface, stick on the new keypad
order by part number here DE34-00233T SWITCH MEMBRANE $20.60 membrane keypad
(We can do this job for you for a total of $64.95, but as you can see, the other two options are more practical and economical)
Take your control box off as in the video at our site, disconnect the keypad strip as shown here, move your circuit board to the new frame, reinstall
order by part number here DE94-01647D ASY CONTROL PANEL $31.77 control panel frame with keypad
Take yours off as in the video at our site, then install the new one
order by part number here DE94-01648D ASY CONTROL, BOX $58.98 complete control panel assembly with frame, keypad and circuit board
Posted on Dec 06, 2009
  • 5370 Answers
SOURCE: How to deal with error
Thie would indicate that the door is not closed properly. Open the door and re-close it.If the door is getting closed properly, then also it can be problem with interlock door switch.You will see, that door is got closed properly, but because the door lock switch is faulty, it will not get properly locked.So the oven will display this error code.Try pressing the closed door hard with your hand.And see, if error disappears.But if door switch is ok and its getting closed properly, then is inverter board issue.The board is not detecting the door is closed so the h95 error is coming up. This inverter board is also used in Panasonic and Bosch units.The door if its getting closed properly, then its inverter board issue.It has to be checked by meter. Click this link directly, to know more about, this inverter board:----
http://cgi.ebay.com.sg/Inverter-Assembly-Panasonic-Microwave-Z606YM300BP-/350038684098 ------------- This should help.Keep updated.Thanks.Helpmech.
Posted on Apr 28, 2011
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
5E (SE) error showing on my samsung C106FL micowave oven (2 years old). None of the other keypad buttons are working. I unplugged the oven & re-plugged next morning but still saem result. Pls help.
The "SE" error indicates a shorted membrane keypad.
You can find support from Samsung in India here.
Dec 18, 2010 | Samsung MC5694 Microwave Oven
Micro does not heat
Without your model number, I'd have to assume that it's a Whirlpool -made Kenmore. If so, then F6 means the cook relay is failing on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 23, 2010 | Kenmore 62702 Microwave Oven
What is a E5 error code in a micro over model number 401.80083700
Dec 04, 2009 | Kenmore 62622 Microwave Oven
After not using for 2 weeks , display panel
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("F2 on display").
Nov 23, 2009 | Kenmore 63792 Microwave Oven
Samsung MR6699GB
This model was one of many subject to a recall due to defective membrane keypads.
Details of the recall are here: http://www.allworldauto.com/recalls/NHTSA_03E044000__SAMSUNG_MICROWAVE_MR6699GB_recall_55168.html
Long story short, please unplug it and contact Samsung with you model and serial number at 800-932-3837.
If your serial number was not one subject to a recall, E2 usually means a temperature sensor problem but it may also mean you have a bad door switch.
If it's not in the recall, please post back and I can give you info on checking the other parts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 13, 2008 | Samsung SMH7174BC Microwave Oven
ERROR CODE E 63 COMES ON AFTER 2 MINUTES ON SAMSUNG MICROWAVE
Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven.  If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
If the message is either ERROR or E-6, it indicates a mechanical fault.
For all error indications, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center
Oct 21, 2007 | Samsung SMH7174BC Microwave Oven
Microwave Ovens Logo
130 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
