Question about Logitech Z-5500 Computer Speakers
Input is on but the sound isn't work - Logitech Z-5500 Computer Speakers
    Problem Solver:
  • 9 Answers
If the power led is lit then check the input selector if OK then check the Audio output IC
Posted on Jan 17, 2014
I have no sound on my vizio tv
Make sure the mute button isn't on. Also sets give you the option to turn off your "on board" speakers. If applicable, make sure this option isn't turned on. Identify if this affects all inputs, and depending on your setup, check you source. Make sure it is in good working order and that your connections are correct. Outside of this, sounds like your set will need to be serviced.
Sep 09, 2012 | Vizio Televison & Video
Lights come on but motor isn't working
1) adjust the REED switch, see the diagram clean it, tight the connector wires.
2) Lube the deck belt very well. VERY IMPORTANT
3) Lube the rollers bearing too,
4) Test the input voltage motor, if there are the Motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Sep 03, 2012 | NordicTrack Treadmill
My sound card isn't working and I have installed drivers now with speakers hooked up it tells me they are unplugged
Test sound via headphones to isolate problem. The green input is for speakers. Some cards will also allow you to change input / output, but this is dependent on their software.
Aug 20, 2012 | Compaq Creative Sound Blaster PCI 64 Sound...
HP w2207 no vga input signal, no dvi input signal monitor goes to sleep
There is no signal coming from your PC.
excuse some of the solutions as sounding dumb, but we have to explore all possibilities.
Check the power cable going into the computer
Check the power input disconnect switch on the back of the power supply and make sure it is on
If the pc is plugged into a power bar, make sure it is turned on and the breaker isn't tripped
press power on the PC and make sure the lights are coming on.
now for the solutions that may actually help.
disconnect the power from the PC
if the video is on a card, remove and re-seat the video card
hook the power back up, connect the monitor and try again.
the CMOS on the computer may need to be reset.
I hate totally clearing the CMOS, so what I usually do is remove 1 stick of ram and power up. If the system is alive again, power down, put the RAM back in and power back up.
If that doesn't work, turn the system off, put the CMOS jumper to the CLEAR position for 15 seconds, put it back to the Normal position and then power back up.
Basically, if the monitor works on your friends system but not on yours, the the problem is your system, not the monitor (assuming it isn't working fine til it gets into windows...if that's the problem, you have a driver or configuration problem)
Jun 10, 2012 | HP Computers & Internet
Sound isn't working on my pioneer 5071 pdp
Does the set have sound with a DVD etc. directly connected to one of the audio/video inputs this set has?
Apr 30, 2012 | Pioneer PDP-5071HD 50 in. Plasma HDTV
Digital Audio Input isn't working
try to reset the receiver (note: all your settings will be lost) :
1 Switch off the unit using the main unit's power switch.
2 Hold the following SPEAKER A button and B button, and turn the main unit's power switch.
3 Check that the entire display is flashing with an interval of about 1 second, and release your fingers from the 2 buttons and the microprocessor will be initialize
assign inputs if necessory and check sound again. If no luck your receiver most likely has a problem with digital board and you need to send it to a repair facility.
Dec 18, 2011 | Denon AVR-785 Receiver
My NAD T65 receiver has problems with the digital sound input. The sound gets choppy when I increase the volume. It seems to be ok at very low volumes, but as soon as I crank it up it fails. It happened...
Could the amp be showing distress, clipping, going into protection? There really isn't much reason for volume of a digital input to have an effect unless the room is shaking so much it's upsetting the digital source device's tracking.
http://www.retrevo.com/support/NAD-T765-Receivers-manual/id/23031ag215/t/2/
Aug 15, 2011 | NAD T765
No audio
Check to make sure all inputs don't get audio. Without a Model number, I can't help you much more than saying to replace the RCA cables on which ever device you're using that isn't giving you sound, and making sure the sound is set properly on your cable box, I.E. if you're using HDMI for your sound input. Also, check the sound setting on the T.V. to see if the sound is still on. Try tapping your T.V. to see if it will make the sound come back if all else fails. If it comes back, then you have bad soldering connections in the T.V.
Jun 20, 2011 | Televison & Video
No Center Sound
it probably isn`t :) it should be a problem with the settings :) i have a str de335 too and i get decent sound.. it depends on what type of source of input u`re using . try this.. hook up a stereo source. go into setup mode.. select wide or normal setting for center, then activate sound field .. c-studio for example.. if the sound is annoying something is wrong with the amp.. :-s btw use the delay settings from 1-6 6 if they are close together :) . When using 5.1 input... turn off soundfield always.. and triple check center settings&levels
Mar 22, 2007 | Sony STR-DE335 Receiver
Logitech Z-5500 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
