Question about Tag Heuer Clothing Accessories
Missing screw on 5502 - Tag Heuer Clothing Accessories
    Master:
  • 966 Answers
Take them to a sun glasses dealer. Usually they will fix the screws free of charge.
Posted on Aug 01, 2013
Technomate 5502 satelite keeps getting scrambled fix please
Hello Robert,
Some further information is required. What type of scrambling are we talking about? Would we be correct in saying that the unit is a TM-5502 HD Satellite Receiver. Below is a link to the Frequently Asked Questions from the Technomate website. try the first part if your have lost channels. If the problem that the unit is not working at all you can try the last step at the bottom of the page. This is the steps to update your receivers software.
If there is any further problems please return here and re post with more information.
We hope that this helps.
Nov 24, 2013 | Computers & Internet
Thule 5502 Anchor Pod RV Kit
go to www. advanceautoparts.com and get it
God bless you
Jul 16, 2013 | Thule 5502 Anchor Pod RV Kit
I do not know how to hook up the speakers to the back of a sherwood RX-5502
You untighten those connections, i mean really untighten them then you will see that there is a whole that you can feed your wires into once you have unscrewed those inputs far enough.
May 26, 2012 | Sherwood RX-5502 Receiver
Unable to connect speaker wires to back of Sherwood 5502 receiver (no way to get them toi stay in)
If you unscrew the red and black knobs a few turns you will expose a small hole that is drilled through each post. Insert the twisted bare wire end into the appropriate hole and tighten the black or red knob to secure it.
Or get connectors as in this article...
http://www.crutchfield.com/S-gtpAzL9W1OZ/learn/learningcenter/home/speakers_wire.html
Jun 07, 2011 | Sherwood RX-5502 Receiver
Hello, I have a Sherwood RX-5502 and currently have a pair of 8Ohm speakers hooked up to the SPEAKER A terminals. Can I hook up a pair of 4Ohm speakers to the SPEAKER B terminals without issue from...
The statement on page 7 might allow enough wiggle room for a single pair of 4-ohm speakers used alone. Procede with caution and don't try to blow the walls down with them. Monitor for excessive heat or strain and if it clips or self-protects back off.
http://www.sherwoodusa.com/pdf/RX-5502(A).pdf
May 30, 2011 | Sherwood RX-5502 Receiver
Tamil nadu free ctv remote service mode
service mode tv Audio Ton CTV 5502 Service Mode
Audio Ton CTV 5502
10.3 90° MONO CTV Service Mode;
Press UP & DOWN buttons together on tv's
local control and then switch on.
Jan 07, 2011 | Televison & Video
Looking for codes sc360 and sc990 gestetner 5502
sc360 is a hard drive detection error. The hard drive might be either defective or disconnected, or one of the connectors might be loose. If you know the hard drive is good, check its power and data cables and connectors. In rare cases, this error can point to a faulty BICU board.
sc990 is a general software error. This error is often logged in conjunction with other errors, and may not necessarily represent a separate problem.
Your best bet is to check the hard drive first -- maybe try formatting it or replacing it if you have an extra one. Good luck!
Oct 19, 2010 | Gestetner - 5502 Digital Imaging System...
Hi: I have a model 0052411 Guardian generator that is putting out 170 volts. Anyone have any idea what has caused this to happen. It has fried any transforms that are in the house. Generac is not much...
Check the automatic voltage regulator .Or if you have a bad neutral connection one leg will be very high and one leg low causing damage to sensitive equiptment.
Oct 19, 2010 | Generac Guardian Series 5502 10 kW...
Sherwood RX-5502 receiver - get no sound.. checked polarity - OK... replaced speaker wire - OK... checked speakers on another device - OK.... tried phono and tuner and cd player - no sound with any........
After doing all this troubleshooting on your receiver, Check if master volume on the surround levels are too low. Adjust master and surround level.
There may aIso incorrect selection of the input source. Select the correct input source.
If after doing this the problem still continue, it means the sound ic in the receiver is damage. the sound ic brings out the sounds from the receiver. You will have to open the receiver to locate the sound ic in the receiver and use the multimeter to read capacitors and change the damage ones.
Thanks for using Fixya.
Jul 11, 2010 | Sherwood RX-5502 Receiver
Clothing Accessories Logo
59 people viewed this question
Top Tag Heuer Clothing Accessories Experts
Da Doc
Tom Chichester
Bill Boyd
Are you a Tag Heuer Clothing Accessory Expert? Answer questions, earn points and help others
