Question about Microwave Ovens
Instruction manual for a Rexon ss-16a fret saw
My dcs mo-24-Ss microwave oven cannot heat the food after turn on, everything working fine other than no microwave come out
Assuming the turntable, inside light, and internal cooling fan all work when you press "Start" to cook, then I would suspect a bad magnetron, or a bad connection at the "FA" terminal of the magnetron.
If one or more of those three items do not work when you hit "Start", the I would suspect a bad door switch or mount.
The DCS MO24SS is essentially a rebranded Sharp R-530E-series microwave with different cosmetics and a higher price.
The service manual for the Sharp model is here.
The internal Sharp parts in the manual will interchange, but not the external cosmetic parts.
You can order Sharp parts from Encompass here.
Nov 22, 2012 | DCS MO-24-SS Microwave Oven
I need a manual for an InSinkErator Pro SS garbage disposal
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Nov 17, 2010 | Microwave Ovens
I would like to know if there is any authorised service centre of braun in faridabad, haryana, india
Please contact these people they will be able o help you out. They are the authorized representative of Braun products in New Delhi
Manocha Enterprises
16a/20 W.E.A Karol Bagh
110005 New Delhi
Phone: 011-25758198/25711168/09811712044
Sep 17, 2010 | Microwave Ovens
Panasonic inverter genius sensor 1250w, turns on for about 3 sec. then goes off, no codes.
try locating the primary door sensor. this is probably burned. replace the door sensor with appropriate amp rating - usually 16A (or higher) 123vac
Feb 09, 2010 | Panasonic Microwave Ovens
I heard a pop and then i saw sparks inside the oven, the sparks were coming from what looks and feels like a paper cover inside the microwave
This sounds like the inner lining is coming off and alloying the metal interior to spark. You will need to repair the liner and this should fix your problem.
Dec 08, 2009 | DCS MO-24-SS Microwave Oven
Mod: BMK 2 SS. Manual has gone missing!
http://www.baumatic.co.uk/products/catalogue/microwaveovens/BTM23.1SS
I beleive this is the same item, not sure why it has a different model number on the website, but you can download the PDF of the manual from the above link.
Oct 07, 2009 | Baumatic BTM231SS Microwave Oven
Where does the light (lamp) in a Kenwood SJ SS 25 microwave go? I ordered a bulb but am unsure of how to put it in when it arrives. The booklet that came with the microwave says "don't do it...
I did not fix the problem. I ordered a bulb (lamp) and subsequently saw it is beyond my knowledge to install it. I'll communicate with the store where I bought it 3 months ago and if they won't deal with it, I'll pay a repairman to do it.
Aug 20, 2008 | Microwave Ovens
I need a part
For replacement parts on LC Penney Cooks merchandise, please call 1-800-933-7115.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | Microwave Ovens
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
