Question about Sewing Machines
How to work PMS3H power management control system for my camper van
Janine Jem platinum 760, ,needle just going up and down, have cleaned and checked feed dogs are up and moving help what's wrong, are the dogs too low is there a adjuster can't find it ?
Make sure the stitch length is set high enough to actually advance the fabric--the feed dogs actually need to move forward and backward.. The stitch length control controls how much the feed dogs move the fabric. Also, check if your machine has a presser foot pressure control. This manages the amount of pressure the presser foot applies to the fabric, causing the feed dogs to grip the fabric in their movement.
If these do not resolve the issue, you may need to take it for service.
Mar 10, 2017 | Platinum Sewing Machines
Pfaff 6230 Foot Control quit working. Light behind Stitch panel, speed, needle down, & 1 stitch at a time doesn't light up. Are these 2 problems? What do I need besides replacing Foot Control?
Um, it could be no power to your machine, I would suspect it is the power cord, plug or possibly an internal electrical issue. If the foot control failed, the machine's light should still work.
Nov 12, 2016 | PfaFF Sewing Machines
Foot control on my Juki 2010 sewing machine is not working, as if there's no power reaching it at all. There is power to my machine as indicated by light coming on when main power switch turned on.
Pam, Could be a bad/broken wire, may be repairable, you should take your pedal in to be tested, if diagnosed to be bad you may have to order a new replacement pedal. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Repair the Foot Control on Your Sewing Machine
http://www.sewingmachinesplus.com/foot-control-419451-003.php?gdftrk=gdfV210602_a_7c3285_a_7c15319_a_7cPID513
Sewing Parts Online Search
Juki Sewing Machines
Jun 09, 2016 | Juki Sewing Machines
Need owners manual for a 2000 trail lite model 8280 camper
contact the manufacturer direct or on line for this
May 02, 2015 | Sewing Machines
The machine power does not work when I press the presser foot
HI THERE
can you please tell me more information about control box model ? so many ways to resolve this problem but it's different from control model to control model , a waiting your reply to tell me control model then i try to do the best to resolve this problem.
thanks and best regards
ASHRAF ABOZID
aabozid@hotmail.com
CAIRO - EGYPT
Feb 22, 2015 | Juki DDL-5550 Industrial Straight Stitch...
Comunication error
At first turn the machine off, and then press the start button, reverse button and auto lock button at the same time.
-Turn the machine back on while still pushing the three buttons. After the machine has powered on, release the buttons.
-Press the + sign at the bottom of the screen, continue pressing each + sign as it appears. The machine will display a "Test Complete" message, turn off your machine.
-Wait 5 to 10 seconds before powering your machine back on, your machine will run through a diagnostic test and repair any issues it finds.
If this doesn't work;
Have you set up communication is to the "COM Port" designation within Customizer/Digitizer.
Go to >ScanCard >Communication Settings > choose the COM Port you want to use (find out what COM port the cable's using by going to your Start/task Bar in Windows>Control Panel >System >Hardware >Device Manager >Ports (COM & LPT).
There, you should be able to see what port your cable's using.
Hope this helps
Nov 03, 2011 | Janome Memory Craft 9000 Computerized...
Using 3D software with 4D reader/writer on XP operating system. Getting error message "reader/writer not found" "VSM reader/writer & embroidery machine USB driver Type A" If I...
Hi Sheila,
Click on start, click on My computer, then look in the left hand menu for View system information and click on it, click on Hardware, click on Device Manager, your VSM reader should show under Universial serial bus controllers, normally at the bottom of the page. If there is a yellow ? mark next to it, it means the driver has not been installed successfully. If so, double click on VSM reader, click on driver, make sure your software CD is in your cd drive and click on Update driver. Should solve your problem.
Aug 31, 2011 | Husqvarna Viking 1
My Bernina Artista 180E no longer works with updated Windows. Is it possible to upgrade so that I can still use my 180E and not have to buy another machine?
Just use the free download software from Bernina called Artlink. I used it along with a USB to Serial converter cable to connect to the machine. Works wonderfully. Allows me to still use my old Artista designer software if I want to on an older machine and then when I want to actually transfer the designs I use the laptop with the USB cable.
Feb 01, 2011 | Bernina Artista 180
My necchi sewing machine stitches too fast
A lot of machines have a speed control, either on the machine or the foot control. I looked thru the manual and did not find anything about speed control. Look under the foot control for a screw that may have a + and - . Otherwise, you may want to take it back to see if service can adjust it for you.
Jan 10, 2018 | Necchi 3537 Mechanical Sewing Machine
Downloading designs from the internet
Disk Manager is part of Customizing software, in case you were wondering if you needed to buy more software. Ask again if you are having trouble locating it. You also need to format your floppy disk in Disk Manager before writing your designs to it.
Jan 22, 2009 | Husqvarna Designer I
Sewing Machines Logo
142 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
