Bake shuts off error f1 model c970642121 - Washing Machines
3 Suggested Answers
  • 530 Answers
SOURCE: 665.95802000 f1 - E 1 error code
take the consol off you will find the tech sheet with all the codes. make sure you turn your power off first.
Posted on Dec 23, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have a Kenmore Model
Welcome to FixYa.
Unfortunately that is an error code indicating the ERC (clock timer) is defective.
The part number for your ERC is 8523666 and is the control to the left when observing from the back...after removing the panel of course.
i.e.
I've attached a helpful link below which should help you identify and assist in purchasing/changing the control for you.
Let me know if you require further assistance and I'll try and help you if I can of course. Good luck.
http://www.youtube.com/watch?v=Pa6mC8W4-ME&feature=player_embedded
Regards,
Macmarkus :)
Posted on Dec 22, 2010
F1 error code and beeps
Hello;
My name is Peter. I am a retired field service appliance technician.
You need to proved me with the oven model number. This number is located on a metal plate, on the top front after you open the door.
The general code F1 indicates a communication problem within your control system.
The code F1 is different depending on the manufacture and model number.
Mar 17, 2015 | Ovens
Dacor RSD30S F1 Error Code
WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN?
small_13_33.jpg For a detailed Range/Stove/Oven illustration, click below.
redarrow.gif Gas Free Standing
redarrow.gif Electric Free Standing
redarrow.gif Gas Cooktop
redarrow.gif Electric Cooktop
redarrow.gif Gas Walloven
redarrow.gif Electric Walloven
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It's stopped completely
It won't bake
It bakes poorly
It won't broil
A burner doesn't work
A burner works only intermittently
I can't adjust the burner temperature
It won't bake or broil
The clock stopped
The temperature is wrong
The oven light doesn't work
There's a self-cleaning problem
The oven door won't close
An indicator light doesn't work correctly
The oven is hot on the outside
I see sparks!
The drip pans need replacing
hope this may help;
Regards,
VOTIT
Jul 30, 2008 | Dacor Preference RSD30 Gas Kitchen Range
What does F1 error code mean when I put into bake?
Good Morning Friend, thank you for allowing me to assist you!
Typically error code F1 indicates that your Frigidaire range has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps! - Z
Jul 06, 2014 | Frigidaire Kitchen Ranges
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My Kenmore stove when I try to bake the oven shuts off and i get a code of E1-F1-
Hello there
Your kenmore product is a whirlpool product actually. The error E1-F1 indicates that the Electronic Range Control/Clock has been blown. Replacing this piece can easily cost you $150+. but is not too hard to replace ok?
Hope this helps
Best regards Mike
May 11, 2011 | Kenmore Kitchen Ranges
Heard pop while baking - control screen quit F1 error message
You will have to replace the control board. you can purchase one online from one of the follow websites. You will need your model number
http://www.searspartsdirect.com/partsdirect/index.action
http://www.apwagner.com/
Nov 16, 2009 | Office Equipment & Supplies
F1 error code on 790 model range
Electronic oven control fault
Oct 06, 2009 | Kenmore Ovens
I get an F1 code when I bake and then it beeps and shuts off an u help.
F1 usually means that that the control board has failed. In rare cased depending on your model, the keypad can also cause an F1. If you disconnect the keypad from the control board and the F1 still comes on, it is definitely the control board. These can be refurbished at fixyourboard.com.
Aug 08, 2009 | Whirlpool RBS245PDS Electric Single Oven
Meat probe button on control pad
there is no real way to reset it you reset it when you turned the breaker off, It sounds like the EOC (electronic oven control) is faulty. I would just keep reset it and keep doing that to bake the turkey how hot will it get before it buzzes? is it showing any error codes?? F1, F2, F3 etc.....
Sep 30, 2007 | Jenn-Air JES9860 Electric Kitchen Range
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
