Question about Maytag M6Y12F2A Air Conditioner
Fan wont turn off in energy saver mode - Maytag M6Y12F2A Air Conditioner
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: Energy Saver setting
Could not find a manual, but that setting is the setting that you choose to leave on and let the air conditioner decide the most effecient way to run during the day. There are too many ways to approach that answer in a small conversation. There are many things to consider and I will leave you with a link to a PDF that explains better of what I am writing. Sea Breeze
http://oee.nrcan.gc.ca/Publications/equipment/pdfs/ac-directory-2006.pdf
http://servicepartstec.blogspot.com/
Posted on Jun 20, 2009
I have a ep08g11b fredrich and on heat it runs all night and when i try to put it on energy saver it blows cold air.
Doesn't this unit only have electric heat, fan and cooling where the energy saver mode is only controlling the cooling? I think it does not do energy saving mode with heat.
Jan 14, 2018 | Dishwashers
How do I get my Samsung fridge model #rs25hs5000bc off demo mode? I tried holding down energy saver and power freezer but doesn't work.
IT is three buttons not two. Cooling Off mode (also called Shop mode), is designed for use by retailers when they display refrigerators on the shop floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and the refrigerator and freezer do not get cold. To start Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button for 5 seconds during normal operation. The refrigerator chime sounds and O-FF appears on the display. To cancel Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button again for 5 seconds, until the chime sounds. Cooling Off mode is only available on refrigerators sold in the U.S. Instructions are on page 20=> HERE
APPLIANCE911
Apr 12, 2016 | Samsung Refrigerators
How do you turn off power saver on frigidaire air conditioner
Good Afternoon Friend,
I understand you want to know how to turn off the power save mode for your Frigidaire air conditioner, model# FFRE12L3Q1. Your appliance will run in energy saver(econ) mode when used for the first time. In this mode, the fan will continue to run for 1 minute after the compressor shuts off. The fan then cycles on for 20 seconds at 10 minute intervals until the room temperature is above the set temperature, at which time the compressor turns back on. You will be able to turn the energy save mode off by selecting your temperature as well as your fan speed. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire Heating & Cooling
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
consumption.
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
Oct 10, 2012 | KitchenAid Ovens
How do i turn off energy saver toshiba e studio 203d
When u press the Energy Saver button, The machine will enter Energy Saver mode where all the display lamps are light off. Just leave Energy Saver mode, just press again the Energy Saver butto
May 18, 2012 | Toshiba e-studio 203sd
My Dometic AC on my travel trailer cools well but I cannot set the fan to stay on when the compressor cycles off. Can a different switch or board be installed to allow the fan to stay on?
An energy saver setting is what it sounds like. Turn off energy saver feature and fan should run 100% and compressor cycle on-off separately.If not familiar with energy saver setting .make sure it has one or not before disregarding this.
Feb 28, 2012 | Dometic Rooftop RV Air Conditioner
How can I turn on the energy saver on my LWHD2400HR air conditioner? There is no switch on the A/C, only an indicator light that says "Energy Saver"?
The Energy Saver mode is activated by using the hand held remote control, that comes with the unit. Pressing the Energy Saver button activates it. Once activated the fan will shut OFF when the the compressor does. After which, about every 3 minutes the fan will turn ON to check the room air to determine if cooling is needed.
It sounds like, you're missing the hand held remote control?
Jul 19, 2011 | LG LWHD2400HR Wall/Window Air Conditioner
Model number HBLG 12303r how does the energy saver setting work bought this model used.
The energy saver setting will turn the blower fan off when the thermostat reaches the desired room temperature (with the compressor). Other non energy savers only cycle the compressor to regulate the room temp. so their fans will operate continusously using more electricity.
Aug 04, 2009 | Heating & Cooling
Do not know how to use the energy saver feature
i have a problem for minolta di351 by code c009 pls help me
Feb 21, 2009 | Toshiba e-Studio 350 Copier
Energy saver mode
THIS CAN BE TURN OFF BY USING THE SETUP MODE, SEE THE MANUAL ON HOW TO ENTER SETUP MODE
May 13, 2007 | Panasonic FP-7735 Black and White Copier
Maytag M6Y12F2A Air Conditioner Logo
15 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
