Question about Ovens
Oven won't stay on and give an F error message
When I turn on the oven it won't stay on. The cpu timer will beep and give a F3 error message. I already replaced the cpu, that was not it. I think it's the sensor 12001655. Can you confirm or is there another area I should look at? Thank you
  • 3 more comments
  • calvalina12 Dec 11, 2007
    I have the same error reading F3. I called the repairman and they said they can't fix it because the serial numbers have been torn off. Can you still fix the problem even without the serial numbers? Does anyone know where the heat sensor is located on this model?
    Any help or suggestions will be helpful.
    Thank you,
    Angelina
  • Emmeril Jan 07, 2008
    My oven will sometimes stay on although occassionally stops, usually it takes holidays off. It displays E6 F2 most of the time and sometimes is totally blank. I have switched off the circut breaker for 1 hour but comes back on with the same code. Will sometimes just beep for no reason. It is approx 7 years old.
  • ErnB Feb 28, 2008
    Oven shows an F7 error. I turned off the main breaker for 10 minutes but error returned after about 10 seconds on restoring power. Also beeps every few seconds.
  • Jill Bo May 06, 2008
    My oven is also given an f3 error. At first it only did it when my oven was what I thought to be over heating. Now sometimes it beeps when its not even on with the f3 error. Instead of pressing cancel like I used to do, I now have to press bake. It's really weird, because when this happens the oven or top range isn't even in use. Please advise
  • Jackie44 Jun 11, 2008
    We had a very strong thunderstorm two nights ago and the power went out abruptly, then a few seconds later came on again. Since then, I also get the F3 error message when I attempt to use my oven. The oven will initially turn on and start to pre-heat, then seconds later, the beeping and F3 error comes on. Could the power outage have affected the sensor? I assume I will have to call a repairman to fix this since I am not an electrician. The one solution offered here sounds like it needs to be done by a professional.
When oven is on and heating up, around 320 degree it will start beeping and display a F7 code. Nothing will stop the beeping or code display except shutting off the power at the breaker box.
Posted on Dec 22, 2007
    Problem Solver:
  • 18 Answers
For those who need the thermostatic limit switches in these ovens, GE wants $30 to $50 for them. You can get them here, from the manufacturer ,,, 2 for $1.00  - wow
CharlyV
http://electronicsurplus.com/ccp74761-thermostatic-switches-36tx22--13038-f230-240-min--36tx22-13038-f230-40-6536.htm
Posted on Oct 20, 2007
    Sniper:
  • 68 Answers
Disconnect the power. Disconnect the sensor harness from the control. Measure the sensor resistance (white leads). The resistance should be 1080 ohms at room temp. If the sensor is open the resistance is usually over 2900 and you get an F3 message. If the sensor is shorted the resistance is usually less than 950 ohms and you get an F4 error message. Also look for damaged harness terminals if not a bad sensor.
Posted on Sep 04, 2007
WHEN MY WHIRLPOOL BUILT IN OVEN MODEL RBS305PRS00 IS BAKING IT SOMETIMES CUT OFF AND YOU HEAR A CLICKING NOISE AND IT WILL DISPLAY EO F3.I CAN TURN THE OVEN OFF AND IT WILL BEEP AND DISPLAY EO F3.AFTE
That's an oven sensor error. Replace the oven sensor. If you still have the error, check the wiring and/or replace the timer/clock board.
Nov 26, 2014 | Whirlpool Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Apr 21, 2014 | Whirlpool Ovens
My frigerdaire oven heats for a while about 15-30 minutes then shuts down with a beeping noise and a f3 code.
Good Afternoon Friend,
I see that your Frigidaire double oven heats up for about 15-30 minutes, then shuts down and begins beeping while showing an F3error code. The F3 states that the oven is sensing a potential runaway temperature. This is possibly a sensor issue or it could be a false error code.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Let the oven heat up, and if you are still receiving an F3 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 27, 2012 | Frigidaire 30 in. Electric Gallery Series...
RS696RXBQ2 - won't heat up, get error message F3 then shuts off.
This tip i wrote explains what the F3 error codes means and what to check to fix your oven.
http://www.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Sep 12, 2011 | Whirlpool Ovens
I turn the oven to 350 and in five second's it beep's and we get a f3 and sometimes f7 this is very frustrating! I take the over off and play with the wires and put it back together and sometimes it will...
I will give you the meaning of the error codes and possible solutions.
F3 Open Sensor circuit, Open (blown) sensor fuse or bad sensor.
More than likely, you have a oven sensor that needs to be replaced.
F7 Problem with the keypanel, possibly, a function pad button is stuck.
Attempt to clean and unstick button. If this fails, you may have to replace the
keypanel.
I hope this helps you
Feb 02, 2011 | GE JKP15 Electric Single Oven
Top electric oven will show an F3 error after being turned on and will beep. Botton oven works fine. Jenn Air electric oven model JJW927AAW. Serial number 11993640WO
HI thanks for your question.. code F3 says to replace the oven sensor, located in the oven. top left corner. Replace the oven sensor. Thanks
Dec 17, 2010 | Jenn-Air Ovens
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My oven displays F3 and beeps
f3 error code is generally a bad oven sensor. not every code is universal, but most manufacturers use the f3 error code to indicate a sensor issue. it is an easy fix if you want to tackle the problem yourself. Joe
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
947 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
