Question about Frigidaire FAA068P7A Air Conditioner
Remove filter from model FAA068P7A Frigidaire air conditioner
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
SOURCE: Frigidaire air conditioner # FAC127P1A1
You can view the manual directly on Frigidaire's website: Use and Care Manual. Look on page 11, under "Care and cleaning". Note that the link is to an Adobe PDF document.
Posted on Jul 09, 2010
Testimonial: "Thank you, Thank you, Thank you!! Just what I needed!"
  • 251 Answers
SOURCE: MY frigidaire Air Conditioner model
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
  • 4736 Answers
SOURCE: Water leaking out of frigidaire
First, have you drained the tank recently. If not, the warning light or auto shutoff failed and the tank may be overflowing. Worse case scenario is the that the tank is dirty and is not allowing the coils to cool and the dripping water you see is from the cooling coils. Since the tank is not removable, it's very difficult, at best to clean the tank.
If you drain the tank and before reinserting the drain plug, try to get about 1/2 teaspoon of bleach in the drain hole. followed by 2 cups of water. Of course you'll have to use a funnel of sort to do this. Reinstall the drain plug and move the unit around so the water and bleach will slosh around. Then run the unit until the bucket is near full again and drain it thoroughly. Look at the color of water draining out, for an indication that there is dirty water. That will be a good indication, that some cleaning of the tank has taken place.
Hope this helped you and thanks for choosing FixYa.
Posted on Jul 29, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire air smells bad
    Clean the front filter and any coils you can reach. Units should be cleaned every year before use. Also make sure you are not circulating air from the outside in and you are bringing in external odors.
    Posted on Aug 17, 2012
    Testimonial: "Thanks for the help. "
    I purchase this aircondtioner at Bestbuy in August 2010. I use it for maybe a month. I live in Connecticut so you only need an Aircondioner June thru September when it is hot. I turned my aircondioner on...
    Hello, if the unit is blowing warm air it could be due to 1) low airflow due to dirty air filter or evapoartor coil 2) low refrigerant charge 3) compressor is not engaging. check the filter first an let me know if it is clean
    Jun 08, 2011 | Frigidaire FAA068P7A Air Conditioner
    I clean the filter almost everyday because it freezes and no cold air comes out.frigidaire faa068p7a is this normal?
    The evaporator maybe dirty. You can flush it water. There is also a spray available at A/C supply for cleaning evaporators. Anyway the evaporator is the radiator looking thing at the front behind the air filter. Air passes through it to provide cooling air. It gets very cold and if the air cannot pass through it will freeze.
    Jul 22, 2010 | Frigidaire FAA068P7A Air Conditioner
    Compressor wont come on
    Check thermostat. Compressor relay. Compressor capacitor.
    May 27, 2010 | Frigidaire FAA068P7A Air Conditioner
    Does the 8000 BTU unit need 15 or 20 amp wiring?
    Find the nameplate ratings if they are still readable for this unit to see what they recommend.
    Ideally a seperate circuit for this unit.
    #14 minimum wire for 15amp
    #12 minimum wire for 20 amp
    May 16, 2010 | Frigidaire FAA068P7A Air Conditioner
    Hi, my Frigidaire AC (FAA068P7A) unit was working fine last year. Put it back in the window today and now it won't power on. I checked the power cord, but cord is fine (I actually opened up the machine...
    Sounds like a breaker has tripped (caused by the unit) or is it might just be 'off' for some reason. I would check the outlet (where the AC plugs in at).
    If the AC is a 110V unit you can check the outlet by plugging in something else, i.e. a hairdryer. If the hairdryer doesn't work either - then you know your breaker is tripped. On the other hand if the hairdryer 'works' then you know the problem is in the unit, where I'm afraid you'd be better off to have a technician to trouble-shoot it, although you could try sending additional information at this point for more help.
    Remember if it is a breaker tripped - it was probably tripped by a malfunctioning Air Conditioner so if it 'trips' again in the immediate future you will need someone to check it out.
    good luck!
    May 03, 2010 | Frigidaire FAA068P7A Air Conditioner
    No power
    change the plug the GFI goes bad in those all the time that should solve the problem
    Apr 08, 2010 | Frigidaire FAA068P7A Air Conditioner
    Checking the filter
    If it is a paper or fiberglas filter it needs to get tosswed. If its a screen type it is washable. Take it out spray it with a mist from a hose from the reverse side to get the dust off, let it dry.
    Then just reinstall.
    Jun 14, 2009 | Frigidaire FAA068P7A Air Conditioner
    Open Questions:
    See all Frigidaire FAA068P7A Air Conditioner Questions
    Frigidaire FAA068P7A Air Conditioner Logo
    94 people viewed this question
    Top Frigidaire Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Bill Long
    Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
