Question about Do All Traps Competitor Transitional Trap
I need a part (the piece that holds the clay target on the throwing arm)
White wing thrower, will not stop throwing clays as soon as you turn it on.
[PDF]TROUBLESHOOTING AUTO TRAPS - kivelaoutdoor.com
www.kivelaoutdoor.com/.../TROUBLE%20SHOOTING%20AUTO%20T...
Is the throwing arm stalled while motor/gears are turning? ... "The Trap worked well at first but after a box of targets it started breaking a lot of .... Throwing Arm when to stopin the cocked position by killing the power to the motor when ... Arm doesn't move to the Disarm position when the unit is switch to Disarm, it could be that.
Sep 14, 2015 | Mtm EZ Throw II
The arm on my clayhawk full **** clay target thrower won't throw!
Anything with this much force in it is dangerous to work on unless you are totally knowledgeable. Seek help from a shop/dealer.
Dec 14, 2013 | Do All Traps Clayhawk Full Cock Clay...
What are the best chokes to use for a beginner on clay pigeon shooting?
To increase your odds of hitting targets - use the most "open" choke that will maintain good density at the distance you're shooting - exactly the same as most experienced shooters do... Skeet choke for shooting Skeet, Mod to Full for Trap, Cyl to Light Mod will handle 95% of shots on the sporting clays courses around here.
To increase your skill - occasionally use your full choke for everything until you learn proper gun mount, swing, and lead and follow through. When you start getting frustrated, switch back to the open chokes to get a little positive feedback on some close targets, then move back to the full choke.
Jan 17, 2013 | Sport & Outdoor - Others
I have some roseart modeling clay and I don't have the box it came in. Can it be dried in the oven and if so how do you do it?
You can dry it in the oven:
1. Preheat the oven to 300 degrees F. Remove all pots and pans from the oven. The clay gives off smoke that adheres to the pots and pans.
2. Place the modeling clay on a baking sheet and set it in the oven. Place it on the bottom shelf of the oven to give more room overhead. To prevent the clay from sticking to the baking sheet, place parchment paper on top of the baking sheet. Once you are finished, it is safe to use the baking sheet for cooking again, just wash it off with warm water and dish soap.
3. Wait at least 20 minutes and check on the clay. Touch the Rose Art clay to see if it is still soft. Larger, thicker clay pieces take longer to bake, so if the clay is still soft place it back in the oven
4. Check the clay every 10 minutes until the entire piece is hard. Once hard, remove it from the oven and allow it time to cool.
Hope it helps out!
May 08, 2011 | Roseart Toys
How do you remove the wiper arm on a 94 Dodge Ram 1500? The arm will not fully extend with the hood open or closed but maybe that doesn't matter. Can't get to the wiper motor without removing the arms to...
throw a grenade at it and hopefully the arms will fly off, whatever happened to a nut on a threaded flange to hold wipers on. No wonder imports own the market.
Aug 15, 2009 | Dodge Ram 1500 Cars & Trucks
2003 Toyota Sequoia Tailgate Latch - how to replace
Remove your tag bolts and remove the cover by pulling easy as not to break the tabs. The tag lights can but do not have to come out. At this point you can access the handle. You will find that the handle has a plastic arm that trips the latch by pulling a cable it will be broken. To open the door just pull on the cable. Once I open the door I removed the inside door panel and a metal cover which has about 8 10mm bolts it gives you more room to work.
Dec 01, 2008 | 2003 Toyota Sequoia
Do All Traps Competitor Transitional Trap Logo
598 people viewed this question
Top Do All Traps Sport & Outdoor - Others Experts
Bill Eager
Are you a Do All Traps Sport and Outdoor - Other Expert? Answer questions, earn points and help others
