Sony str 471 no power,where is the fuse on this receiver
SOURCE: Sony STR DG 510 receiver manual
Hey there, found it on the sony site...
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=STRDG510
Hope that helps.
Posted on Oct 19, 2007
SOURCE: STR DE435 PROTECTOR STR DE435
I have the same problemwith mine. the protector sign is on- I do not know why- and do not know what to do about it. Let meknow if you do or if you get assistance and I will do the same. My e-mail address is 1971CJS@Bellsouth.net
Posted on Feb 28, 2008
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
renosean
  • 492 Answers
SOURCE: receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Posted on Jan 04, 2009
SOURCE: left channel is out sony STR-D511
Had the same problem but found simple solution. I just reconnected the speakers which were on "A" connections to the "B" set of connectors immediately below - problem solved!
Hope this works for you.
Stuart
Posted on Jan 22, 2009
I have a SONY STR DE915 receiver home theater amp. After 14 years, it decides not to power up! Are there internal fuses? Can i replace the power supply myself?
There are internal fuses that you can check. This model was notoriously bad for amp problems. These amps would burn up a lot of components when they go out.
Oct 11, 2013 | Sony STR-DE915
Sony receiver str-dg800 will not power on.
Unplug the unit from the wall and remove the outer case. At the rear of the main circuit board is a fuse. Check the fuse to see if its blown. If not, go to the transfomer at the front of the receiver and check the fuses at the transformer.
Aug 28, 2010 | Sony STR-DG800 Receiver
Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
Feb 13, 2010 | Sony STR-DE445 Receiver
No sound output sony str
Unplug and replug connections in firmly and try again. Nothing? Check that the subwoofer is getting power. The sub sometimes has a built in fuse. Check that the fuse is not blown.
Feb 12, 2010 | Sony STR-DH500 A/V Receiver
I have a Sony STR DB930. Something happend and it
The fuse blowing is a symptom of something seriously shorted internally. What preceded the initial problem? Smoke is bad. Fire would be soon to follow without the fuse blowing. Take it to a tech.
Feb 08, 2010 | Sony STR-DB930 Receiver
Sony STR-D565 fuse continues to blow
You could have a shorted winding in the power transformer. The diodes in the power supply can be shorted. Filter capacitors can short and send power to ground which will blow the fuse.
Apr 16, 2017 | Sony STR-D565 Receiver
I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Apr 04, 2009 | Sony STR-D565 Receiver
 Grubhead
Grubhead
