Question about PowerPro Power Pro B100 97 98 Bmw A/c Condenser Fan 64548380780 34455005200 Bm3113110 E39 5 Series 528i 540i Behr
1997 BMW 528i has been over heating , and does not
1997 BMW 528i has been over heating , and does not go over 25 mph ,
2010 bmw528i will not start shows break light despite new breaks and fluid and shows a sign with the car tilted
BMW 528i won't start - YouTube
? 1:25
www.youtube.com/watch?v=qEGz4Q6FGVI
Feb 22, 2012 - Uploaded by willnbren2
I have a question regarding my 98 528i , it will crank once but not start then I retry it won't crank but I can hear the fuel pump humming , I have to ...
Sep 24, 2015 | 2010 BMW 528i
Cant open the trunk on 1997 e39 BMW 528i
you should be able to tip the rear seat you should be able to trip the lock but check for a release cable around the rear deck, much easier
Jan 03, 2014 | 1997 BMW 5 Series
1997 BMW 528i IS OVER HEATING , DO YOU KNOW WHY
Recent hot weather, yesterday I just mention cars, from mentioning the car to open a total of twice now, each time he comes out of the heat engine billowing long time are not loose (one or two hours a ghost) we have not same situation?
we may need a professional OBD2 diagnostic tool http://www.spobd2.com/wholesale/bmw-icom-a2-b-c-diagnostic-and-programming-tool.html to assistant us find out the solutions
Jul 31, 2013 | PowerPro Power Pro B100 97 98 Bmw A/c...
How do I take apart my rear door of my 1998 BMW
the motor isn't bad. it doesn't get enough use to go bad. The clip holding the cable that makes the window go up and down broke.
google: window regulator repair clip 1997 bmw 528i. 97's and 98's are similar. 99 they changed them. they all break. they all break in the same place! It's the clip. 25 bucks order a repair kit from the guy. it's the same work as buying a $150 new regulator that will break again anyway
Mar 19, 2010 | 1998 BMW 5 Series
HOW SERPENTINE BELT IS REPLACE ON A 528I BMW
This was Posted under the Serpentine Belt Tool Category and not the Cars & Truck Category, delaying response. My apologies...
I do not know if you still need this information.
I also do not know what Year your BMW 528i is, as the 5-series were manufactured from 1997 thru 2004.
Click on the following Link. Regardless of your Year it should have the Diagram's and Photo's you need to Remove and Replace your Serpentine Belt, including the procedure in loosening the Tensioner.
http://www.2carpros.com/car_repair_information/year/1997/make/bmw/model/528i/1997_bmw_528i_drive_belt_routing_diagram.htm
Feb 20, 2010 | Lisle Serpentine Belt Tool
97 BMW 528I NEED DRIVE BELT DIAGRAM
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
Nov 10, 2009 | 1997 BMW 318
Put in a new wiper motor 1997 e39 528i bmw\it stops in the middle
Remove arm(s), put wiper motor in park,(shut off) then re-install arm at base of windshield where they were before,when shut off.(in park position.)
Sep 26, 2009 | 1997 BMW 318
The rear passenger window on my 1997 BMW 528i stuck in the open position. I heard a cable snap and need to get it repaired, but would like to know how to remove the inside panel so that i can prop up the...
you need a cable kit replacement. 25 bucks.
google: 1997 BMW 528i regulator repair kit. 97's and 98 are the same, 99's are diff. the same clip breaks in all of them. this guy has invented a permanent fix for it. same work repairing as replacing, only difference is that after repairing it, it wont break again!
Jun 30, 2009 | 2008 BMW 528i Sedan
PowerPro Power Pro B100 97 98 Bmw A/c Condenser Fan 64548380780 34455005200 Bm3113110 E39 5 Series 528i 540i Behr Logo
15 people viewed this question
Top PowerPro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a PowerPro Heating and Cooling Expert? Answer questions, earn points and help others
