Question about Zebra QL 320 Plus Thermal Printer
Connect wireless how do I connect to my laptop
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Nov 01, 2012 | Toshiba Computers & Internet
D-link DIR-625 wireless router is setup and wired to laptop
First of all make sure the Wireless switch in your Laptop is turned on.
Now Disconnect the cable from the Laptop to the Wireless router
Now go to your Wireless Network connection and search for the available network. Select the appropriate network and connect.
Thanks
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
My lap top isnt set up for wireless connection to internet
Connecting laptop/computer to wireless router
If you have a wireless router and it is connected to the DSLor cable modem and Internet then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jun 16, 2012 | Samsung Computers & Internet
Limited connection
Limited connectivity
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
May 03, 2012 | Dell Latitude D610 Laptop Computer -...
Suddenly unable to connect to wireless network
Apr 02, 2012 | Dell Inspiron M501r Laptop Computer (AMD...
Wireless Connection
1. go to Start->control panel->network connections->wireless connection. 2. There you will find an option of repairing the wireless connection. select it and repair your connection.
Aug 30, 2009 | Acer Aspire 4315 Notebook
Cant connect printer to wireless laptop.
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
Apr 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
VAIO BX51VN Laptop
check the connection frequency it might not be the same on your laptop and your wireless in which case you'll need to get one that is.
Jun 26, 2008 | Sony VAIO VGN-FE870E/H Notebook
Zebra QL 320 Plus Thermal Printer Logo
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
