No matter which cycle I now choose, each time, it goes through the motions (using the same water already sitting in there) and ''clicks'' like normal as it goes through each phase of the cycle, but even at the very end, still does not drain out. Model number is Maytag LAT8624AAE.
Hello friend, I appreciate your post!
Based off the information you have provided if your Frigidaire washer is draining and rinsing but not spinning it could be an issue with your timer or motor. I would reset your appliance by disconnecting power to it by unplugging it or flipping the household circuit breaker for ten minutes. If that does not work I would recommend having a technician out to the home to properly diagnose and repair the appliance, since it could be any one of these underlying issues. Hope this helps. -Matt
