Question about Bosch 36V / 1.3 Ah Lithium-Ion Battery
Take battery apart - Bosch 36V / 1.3 Ah Lithium-Ion Battery
The battery seems not to have enough power for it the toothbrush to operate normally.
There is such a thing as new batteries, however, many or most electric toothbrushes do not have any way to replace those batteries, they are made to throw away once the batteries die.
If you can get it apart, you would see that, but you might have to break it to take it apart. Also, there is not much guarantee that replacement batteries are available.
Sorry.
God bless your efforts.
Mar 21, 2016 | Health & Beauty
Replacement due to battery swelling?
this indicates that the wrong charger was used for the battery type
it is a result of too fast a charge or the wrong charge (metal hydrox batteries against nicad batteries )
Sep 04, 2015 | Tablets & eReaders
How do you change the battery in the remote key chain?
Use a small flat screw driver to pry apart the 2 haves of the remote transmitter. When you have it apart check to see if the battery hold down is soldered in place, very common for it to come apart.
Mar 15, 2013 | 2005 Chevrolet Cobalt
No power to computer. Battery cable recharger led lites up
If the cable and battery are good, you will need a tech. Taking apart a laptop is a touchy thing. If you are an electrician, you have to take it apart and test the wiring...but I warn you, parts in laptops are not made to come apart and go back together many times...connections are like paint, and wear of with a few reconnections and it's easy to permanently break it.
Jan 12, 2010 | HP Computers & Internet
Sylvania SMPK8854 How to change battery? How does the unit come apart to install a new battery?
to take apart just look for the little rubber plugs on the back bottom of the player you will need a very small phillips head screw driver to take it apart just be very carefull pulling it apart i did mine just fine i broke my screen to mine but guess what it still works you just have to know were to touch but no movies for me any more i need a new screen but anyways chech with geek squad they might be able to get you a new battery....=)
Dec 28, 2009 | Sylvania SMPK8854 Digital Media Player
How do I replace the CMOS battery for Toshiba Satellite A10-S169. Thank you
The cmos battery in laptops is not easily replaced. The whole laptop must be taken apart to get at the cmos battery which is soldered to the motherboard. You should be able to find a new battery on ebay but then will require someone to take it all apart and resolder the new battery onto the motherboard
Jul 07, 2009 | Toshiba Satellite A10-S169 Notebook
How do you replace the battery in the remote control with key?
the switchblade key comes apart buy lightly prying the 2 halves apart with a pocket screwdriver then the half that has the buttons will pop apart like a watch the battery is a watch/hearing aid battery, think the number is c2023
Mar 15, 2009 | 2004 Volkswagen New Beetle Convertible
VW Jetta keyless entry remote not working
newer remotes just pull apart, no screws
first detached the half with the pivoting key
just pull that half away from the other half
on the half without the key attach
it splits apart to expose the battery (usually a 2032 watch battery)
you may need a small flat head screw driver to help to split it apart
Mar 10, 2009 | 2002 Volkswagen Jetta TDI
Key remote
you have to pull apart your remote in a way that you need to hold it lenghtwise with your hands on each side and you make a good effort to separate the remote in two parts and then you have access to the battery.Good luck.
Nov 18, 2008 | 2001 Volkswagen Jetta TDI
Battery replacement
There is a button for the battery cover release on the bottom of the mouse. Slide the wireless usb adapter out and the button should be there.
Nov 05, 2008 | Logitech 3-Button Cordless Optical Scroll...
Bosch 36V / 1.3 Ah Lithium-Ion Battery Logo
27 people viewed this question
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
