Question about Ricoh Aficio MP3350
Red light start button scanner - Ricoh Aficio MP3350
the problem may be the scanner are you able to scan to pc or email/fax from the machine glass/
when the machine initializes are there any faults displayed ( the printer will continue to function even if the scanner fails) usually the error code 30.01.02 or something like that will be displayed-
the scanner is connected via 1 large connector found to the rear of the machine - does the cable look damaged in any way- is the connection 'good' has the grounding wire worked loose, if after these have been checked there is still no scanner then you may need either a scanner or main PCA/formatter fot the printer.
Belmonte business are able to help with the repair of this unit should it be required and would be subject to the usual costs.
available on 0161 480 5556
Dec 31, 2013 | HP LaserJet 4345mfp Printer
The scanner is connected properly and I've used it for years. I turned on the scanner today and the power button on front lights green, then I hear a jerking sound and the light immediately starts...
Check if the transportation lock is in the unlocked position; this is on the back above the USB port. Disconnect any accessories that could be malfunctioning. Then turn the unit off and back on. If the unit responds properly, it was a temporary problem. Retry the accessories. Otherwise, the unit needs service. You will need to determine if the cost of service is worthwhile.
The flashing red light can indicate the fluorescent lamp needs to be replaced or the scanner is malfunctioning. From the sound you describe, I suspect it could be a problem with the motor or the path that the scanning unit has to travel.
I hope this helps.
Feb 11, 2011 | Epson Perfection 3170 Flatbed Scanner
Red flashing light on power button - scanner was recently dropped.
Check to make sure the "transportation lock" on the botom of the unit hasn't got knocked to the lock position. That would make the red light flash on that model.
Nov 26, 2009 | Epson Perfection 1670 Flatbed Scanner
My epson 3490 photo scanner isn't working theres a red light on the front of the scanner which is flashing
If the start button light is flashing red, it is because of one of the following problems:
  • The scanner is not connected to your computer properly or your software is not fully installed.
  • The transportation lock is locked. Slide the lock to the unlock position.
After trying these solutions, unplug the scanner to turn it off, then plug it back in.
Sep 30, 2009 | Epson Perfection 3490 PHOTO Flatbed...
When red light is flasing on and off what may be the problem? on epson scanner
Aug 23, 2009 | Epson Office Equipment & Supplies
Epson perfection 2400 photo scanner stuck with flashing red light
You may have accidently pushed the LOCK button - this button is used to LOCK the carriage into place when moving the scanner to another location or shipping it.
Check for a button and the picture of a LOCK, it is usually at the back of the scanner, you can push it left or right, and you have an open lock and a closed lock picture under it. Make sure you didn't accidently push it to the LOCK position when holding the scanner - that loud sound means your carriage is locked and cannot move - once you set the button to UNLOCK this should solve your problem.
Jul 27, 2009 | Epson Perfection 2400 Photo Flatbed...
Kodak I1220
Kodak i1210 the red led is flashing and no work
Jun 24, 2009 | Kodak i1220 Pass-Through Scanner
Red light flashing on power button after attempting a scan, making a funny jerky sound like a jammed mechanism
Found online epson manual, found that lock tab on the back of the scanner had been bumped across to "lock" position.
Jun 18, 2009 | Epson Perfection V700 PHOTO Flatbed...
The red light on the scanner seems to be on most of the time
If you are using magellan 1000i with no button, then it must be your scanner broken. But If you use a button trigger try to push it a while. The Button is on top of the scanner,with a white / light green color.
Aug 10, 2007 | PSC Magellan 1000i Barcode Scanner - P/N...
Scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Jul 26, 2007 | Epson Expression 1640XL Flatbed Scanner
Ricoh Aficio MP3350 Logo
27 people viewed this question
Top Ricoh Computers & Internet Experts
Bernard D'Souza
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
