Question about Car Audio & Video
Lineout for ford radio F5TF-19B131-AA - Car Audio & Video
2 Suggested Answers
97F350diesel
  • 1326 Answers
SOURCE: Have stock radio # F75F-19B131-AA its in a 1998
You will need a line level converter for starters (takes speaker level signal and converts it to line level/RCA signal) you connect this to the speaker left/right wires and it has a RCA left right on other end to connect and run to your amps, (you need this box because factory radios don't have RCA outputs on them) At that point all you have to do next is run the power/gnd/rem for your amp and then speaker wires to your front/rear speaker and then sub (if using). You can use one of these converters for your front/back speakers so you will still have use of your front/back/left/right fading options. make sure you disconnect th factory plug/harness at each speaker since the amp will be powering them and you will run speaker wires to each speaker. If you only want one converter it will be on your front channel and your sub will be power by the front. (you will fade to front for more/less sub bass unless your amp has a separate volume/bass control). If you want your sub to fade with rear speakers you will need to install another converter off of the rear speakers. Found a site with some photos that may help you with your project.
http://www.redlineforums.com/forums/howto-section/15003-how-sub-stereo-amp-install-factory.html
Posted on Aug 18, 2009
Testimonial: "Told me things I sure didnt know"
Plez anybody knows ford figo 4 digit tape code for AS69-18D804-AA....A12303541...plz help
Check in your owners manual. Otherwise, you will have to contact your dealer..
Nov 17, 2015 | Ford Cars & Trucks
F5TF-19B132-BA Ford Radio Pin out
The stereo pin layout can be obtained from the car dealership, also a repair manual should have the stereo wiring harness layout in it , the stereo harness adapter for installing non oem stereo, found at the local auto parts store will come with the wiring layout, wires are color coded too, sometimes the stereo harness or stereo harness adapter will have small writing on the wires itself, showing you what that wire is for, and where it should connect.
Basically it comes down to, obtaining the stereo wiring layout, read the description on the wires, and properly connect them together, then solder the wires or crimp them, I like to solder mine with soldering wire for electronics, and put shrink tubes to protect the wires, put the shrink tubes on the wires before soldering together, and ensure the shrink tube is the proper size awg wire gauge.
You will also need, aftermarket face adapter kit and antenna adapter, if installing aftermarket stereo.
Hope this helps and enjoy the stereo :)
Apr 11, 2015 | 1999 Ford Taurus
Wiring diagram
have you ever had someone ask a question and leave yo
Oct 01, 2014 | Radio Communications
PINOUT FOR FORD FOTF-19B132-AA RADIO
1990 Ford F150 Truck Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Sep 13, 2012 | 1990 Ford F150
Need code for 6000ne model ys4f-18c815-aa s/no m483753
Please visit here & for a nominal amount recover your code.
Apr 25, 2012 | 2003 Ford Focus
Codigo radio cd ford 6000 ne ys4f-18c815-ad
Post the SERIAL NUMBER found on a label on the radio casing
Dec 28, 2009 | 2000 Ford Focus
Code for a Ford Mondeo 6000cd radio
Hi Geof
Your radio code number should read: 5796.
I trust this will do the job.
I have no other code for your model.
Please let me know if this works.
Bye Ray
Sep 02, 2009 | 2001 Ford Focus
Have stock radio # F75F-19B131-AA its in a 1998 F250 need to know how and if i can hook up one Amp for the two door speakers, and if i can hook up an additional Amp for some subs. Ofcourse if radio can do...
Aug 18, 2009 | Car Audio & Video
Car Audio & Video Logo
120 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
