Question about Nokia N95 Cellular Phone
How to reset time on nissan wingroad 2006 consol panel
Where is the fuel filter of the nissan wingroad 2002
I think on that model the filter is inside the fuel tank as part of the fuel gauge assembly.
There will be an access panel in the floor under the rear seat base.
Dec 31, 2012 | Nissan Cars & Trucks
2006 wingroad 1800, cvt, my car has trouble starting in the mornings like it is starving for fuel
fuel filter clogged.do a little tune up if you have not done one in a long while.
Oct 21, 2012 | Nissan Cars & Trucks
Why is clamate control on 2006 wingroad ultra sensitive?
This can be caused by a bad controls or bad blend door motor, the door motor and controller will need to be tested to see which is causing the problem,
when you say temp fluctuates what happens? are you using the a/c and you turn temp down one click and it goes to hot ?
Is the temp going from hot to cold hot to cold as you drive?
Aug 12, 2012 | Nissan Cars & Trucks
The abs light on my nissan wingroad 2004 model is constantly staying on the dash board. Also, the speedometer is not working and when I mash a sudden brakes the car swerves at the back.
Hi, This means your ABS is not working at all, first check out your fuses before anything else, next bleed the ABS system or even the brakes as this means air has got into the system! Check any leaking brake fluid from pressure hoses. Please leave me feedback thanks, Malcolm Campbell.
Aug 22, 2011 | 2006 Nissan Z
The Abs lights in the Nissan Wingroad is on, how to turn it off? also the speedo metre is not working. will it be related?
you need to have faults read. you need a scanner to read codes and any good parts store or shop can scan and tell you what needs to be repaired or what triggered fault. Once fault is fixed they cabn reset lights for you.
Jan 07, 2011 | 2006 Nissan Z
Rapidly fluctuating tachometer. Nissan Wingroad 1999.
You must be right, the sensor connection could have been moved. Have the mechanic do the checking.
Oct 02, 2009 | 2006 Nissan Z
Nokia N95 Cellular Phone Logo
43 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
