Question about LG E2350VR 23" Monitor
Easy set package - LG E2350VR 23" Monitor
I downloaded a Linux program from the Internet to my download directory. How can I install it?
It depends on situation.
What is your operating system?
Windows:
No easy way exists to run Linux program in windows. Use VirtualBox or VMware virtual environment, download Linux OS, install virtual Linux machine and then install your downloaded program in Linux.
VirtualBox free download (virtual environment):
Welcome to VirtualBox org
Ubuntu Linux OS free download (virtual machine):
http://www.ubuntu.com/download/desktop
Your final installation set look:
Your downloaded program
Linux operating system - installed as virtual machine
Virtual environment
Windows OS
These components are installed on computer
Linux:
There exists more program packages types :
RPM package installation (Centos, RedHat, OpenSuse...)
rpm -ivh program_name.rpm
Debian package installation (Ubuntu, Debian...)
sudo dpkg -i program_name.deb
or
sudo apt get install program_name
General compressed file / installator
File extesion examples:
package_name.tgz
package_name.tar.gz:
Unpacking
tar -xvzf program_name.tgz
Installation of executable file :
./install.sh
(or another file from the package)
Jan 19, 2016 | Computers & Internet
Tip
HOW TO INSTALL FROM SOURCE IN LINUX
HOW TO INSTALL FROM SOURCE IN UBUNTU 9.10
Installing from source in linux is not very easy...... but once you know what to do, then it becomes a very easy task.
STEP 1 Tar.gz and Tar.bz2 Packages
The installation procedure for software that comes in tar.gz and tar.bz2 packages isn't always the same, but usually it's like this:
1.Download the tar.gz or tar.bz2 package
2.Extract the file
3.Open to the terminal
4.Use the cd command to change to the directory where the package is extracted
5.Use the following:
$ ./configure
$ make
$ make install
Without Using The Extraction Method
Run the following:
$ tar xvzf package.tar.gz (or tar xvjf package.tar.bz2)
$ cd package
$ ./configure
$ make
$ make install
!!!!THIS IS AWESOME!!! …... ISN'T IT?
STEP 2 .Deb Packages
Installation of .deb packages are in different forms or methods depending on the users understanding and how the user is flexible with the terminal.
1.Download the package
2.Extract the package
3.Change to the directory containing the package
4.Run the following
sudo dpkg -i package_file.deb
!!!! AND YOU ARE DONE!!!
LINUX X64 AND X86 BINARY INSTALLATION
2.Open to the terminal
3.Use the cd command to change to the directory containing the package
FOR X86 PACKAGES.........
$ chmod +x filename-ver.*-linux-i686.run
$ sudo ./filename-ver.*-linux-i686.runFOR X64 PACKAGES........
$ chmod +x filename-ver.*-linux-x86_64.run
$ sudo ./filename-ver.*-linux-x86_64.run
where ver is the version number (the whole number before the decimal point... eg; the 4 in 4.103)
!!!!THANKS A LOT!!!!
on Jul 21, 2010 | Computers & Internet
How much salt to put in 18x48 pool frist time
Frame Set or Easy Set?
If Frame Set = About 6,400 Gallons
If Easy Set = About 5,450 Gallons
Salt levels in a pool for a generator to operate efficiently...
2700 ppm Minimum to 3400 ppm Maximum, 3200 being Ideal.
So...
In pool water with NO Salt reading at all - 0, then you will add 2.67 lbs. of "Pool Salt" (which is almost Food Grade Quality! - NOT Softener Salt!) per 100 gallons of capacity.
This chart has lots of useful info: take a look
https://www.hayward-pool.com/pdf/manuals/Salt&SwimChemistryGuide.pdf
Jun 19, 2014 | Intex 18' x 48" Easy Set Pool Package
Need instructions for Easy Bake Decorating Sensation Frosting Pen
Sorry, I have no information on these devices.
Dec 23, 2011 | Cars & Trucks
How do you fix a code p0700 and 70-03 on a honda hrv? the Honda is shaking when is stopped and sometimes accelerates when it is stoped
The 700 is a generic transmission malfuction code. Anything that goes wrong wih the solenoid package will set this code. The other I haven't seen, typo maybe? If it is 703 then it is a brake switch circuit b malfuntion. The 700 will need more diagnostics to find whats exactly wrong with it, or you can replace the entire solenoid package in the transmission. 703 replace the brake switch on the brake pedal. Most solenoid packages come out fairly easy, just messy. Drop the pan,lots of oil, remove the filter,usually just snaps in, some bolt in, About a dozen bolts and remove the solenoid package.
Apr 19, 2011 | Honda CR-V Cars & Trucks
Need help Updating PHP 5.1 to PHP 5.3 on Cent OS VPS Getting a lot of errors, if it's not one thing it's another. Any Assistance would be great. -Cherie Error posted...
Click close the internet site when such messages are displayed to display a new page. The computer devices occasionally encounter misunderstood requests. Since computers communcate in unique figures and letters is reason to display unrecognisable details once an inpossible request encounter were made. unless the network were malfuntioning from another device causing message display, the computer should continue to function soon after click close and open once more.
Feb 09, 2011 | Computers & Internet
I am having difficulty setting up my TimerMax XT and note that there are no detailed instructions in the package. Are there some instructions on line? John
I can't find online instructions.
I did find that you can only set ON and OFF times on the hour, if that is any help.
Other owners claim that it is very easy to set.
Good Luck.
Dec 21, 2010 | Stanley 38468 TimerMax XT Extreme...
Easy Set Package software is not functional at the LG E2250
I have the same problem. I wrote to LG and here is what they responded:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6464
Easy Set requires proper communication between the software and the monitor in order to work properly. To do this it has to go through Windows and the graphics driver. Not every setup is going to support this. If the dual web mode cannot “see” a monitor it supports, it will be grayed out.
I have an nVidia FX 5500 and latest driver.
So it seams I need a PC upgrade.
May 23, 2010 | LG Computers & Internet
Easy set package won't open. Monitor Driver won't install.
Hi mquinhoneiro,
I got the same problem. Probably there is something with EasySet Package. First time I installed driver + easyset like instruction said a I got "osd locked".
My solution:
1. Unistall your ati/nvidia driver with control panels
2. restart computer
3. you monitor probably will display 640x480 standard resolution
4. system recognise your vga card and install standard driver
5. restart
6. install lg driver depend on our monitor and connection
7. then should work. if not
b) install again but this time when you press install hold for 10 seconds  menu button.
8. update driver from nvidia/ati site.
For me this help but easyshare wont install again. But I don't use it .
Anyway monitor is good for the price but have little "cool" colors (perhaps from blue lcd led).
My configuration for ~6500k setting
gamma 0
red 55    ( 60 if you want more red)
blue 55   (45)
green 55  (45)
brightness 48 saturation 70
Peter
Apr 20, 2010 | LG E2350VR 23" Monitor
Rinnai tankless water heater vertical vent installation
i would sugges the vertical vent comes as a complete package so i would return the complete horizontal package and ask for vertical
Nov 09, 2008 | Rinnai Water Heaters
LG E2350VR 23" Monitor Logo
41 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
