Got an lg 50pc56 tv one day used it hdmi worked the next day it didn't in both ports tried new cable and still nothing and tried component using a scart lead which then works so i know it is down to the tv some how
  • 4102 Answers
SOURCE: hdmi not working on brand new haier hd tv
are you using hdmi leads and how are you recieving hd are you recieving it through a box
Posted on Jan 16, 2008
SOURCE: HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
Posted on Jan 18, 2008
SOURCE: Maxent MX50X3 HDMI input
I had the same problem and found that the ground wire outside where the cable companys box is was not even hooked up. It was just hanging there, once I hooked it up it went away. The cable company gave me the run around telling me it wasn't their fault. I now have Direct Tv.
Posted on Jun 17, 2008
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
  • 4234 Answers
SOURCE: my sharp tv is pc ready. I hook everything up and
There are a number of things to check here:
1) Verify that the resolution on the PC is set to a supported level for the TV. Usually the TV will show "no signal" if the resolution is out of range or the message "out of range" will appear.
2) You don't indicate whether you are connecting to a desktop or laptop. If a laptop, you may need to turn on the external monitor. This is done by using the function key and either F5 or F6 (the key should have a picture of a screen on it). Hitting this combination will toggle between the main screen with.without the external monitor.
3) Verify that the TV port is selected correctly (AV1,AV2 etc)
4) You will need a separate cable or the audio regardless of the system type. Also verify that the audio cable is in the corresponding audio input jacks for the video option selected.
If you have completed the above and it still doesn't work, please post the details about the computer being used and the exact cable setup that you have and I'll check into this further.
Thanks,
Dan
Posted on Mar 13, 2010
How can I get the best HD (cable) signal to my old HD TV with no HDMI port. The TV only has Component Video, S-Video, RGB input, and of course Coax input. The TV is an LG DLP TV.
If it is an hd compatible tv the is has to have either an hdmi port or a dvi port. Our old projection tv was hd but before the current hdmi format so we had to use an hdmi to dvi conversion cable. If it doesn't have either of these then it probably isn't hd compatible.
Nov 15, 2017 | LG Televison & Video
Viera TH-L39E5K. Why isn't HDMI connection working?
Try a different HDMI cable first into all ports. Try every HDMI cable you have. Then try a different component into TV HDMI ports. If you are using the receiver to switch inputs, try running HDMI cable straight into TV. HDMI is very finicky. Some cables won't work or stop working for no apparent reason.
Nov 02, 2015 | Panasonic Televison & Video
Hdmi ports 1and 2 are disabled what can i use in place of hdmi to make it work
A PS3 Component cable would be the next best option if the TV has Component connections
Jul 09, 2014 | Sony Playstation 3 (PS3) Console
LG Tv M227WDL HDMI black screen
If the HDMI input is failing you will need to ring Customer Support or Get a New TV because if its not outputting then The HDMI may not get Prosecced (sorry about spelling) And make sure you have checked its the Correct port and that there is no Blue-Tac or dust in the port ( that ussually solves this) If all else fails Use a Hairdyer and give it a Big clean :D
Mar 14, 2014 | Televison & Video
No signal on HDMI ports?
Don't know what the cat could have done, but this is usally a problem with Satellite users after a near lightnig event. Does not have to be a direct hit to the receiver. Since you tried everthing with another TV ,Right? and it worked you will need a new main board for the TV if you wish to use HDMI
Feb 15, 2014 | LG 47 47LW5600 47 3D LCD TV
LG 37LC2D-EC
It sounds like the TV is having sync issues with your Sky+HD box. HDCP is the "High-bandwidth Digital Content Protection" that is used between components. It requires a sync between the devices to ensure that you are not trying to "steal" the video content you are watching. This intermittent message and blacking of the screen is good evidence that this is your problem.
Even though the HDMI cable worked fine on another set, I'd try a new one anyway. Some TVs and components are more sensitive than others, and a weakened cable may not show a problem on one set, yet show it on another.
Barring the new cable not working, check LG's website for a possible firmware update for your TV, and also try using a different video source, like BluRay and see you have the same problems.
Beyond that, it may just be an issue with the TV itself starting to die.
Sep 15, 2012 | LG 37LC2D Television
Hello I received a lg flatron plasma MZ42PZ14 and just wanted to connect the tv cable to the tv, but i can't find any coax on the tv. what can i do?
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Jan 22, 2011 | LG MZ-42PZ14 42 in. Plasma Television
Use an HDMI cable from my LG DVB-T HDD/DVD recorder
A quick google search of that model number turns up that tv doesn't have an HDMI port. Your next option would just use component cables instead. At 26 inches you will never notice the difference.
Dec 23, 2009 | Philips 26PF9956 26 in. Television
I have an LG 42LC2D TV with INVALID FORMAT ON HDMI2
I have had this same issue.
Problem your tv isnt true 1080p meaning it will not work however when you switch to componet cables goto menu then change the display settings to 720p or 1080i then your HDMI connection should work fine.
Dec 12, 2009 | Televison & Video
Panasonic home theater
switch the HDMI cable to another HDMI port (if available).
or use and AVI/COMPONENT to make sure the device (HOME THEATHER) is working fine.
Try also another HDMI cable or hook another device into it to see how it works.
If you determine the HDMI port in not working properly, then your Mainboard is damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
May 14, 2009 | LG 50PG20 50 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
