Orion tv1334 my school's cable is changing and it wont work unless it has a Qam tuner thing. does it?
3 Suggested Answers
SOURCE: Universial Remote Code for Orion Model TV1334
want the diagram of orion tv 1334 for know one´s piece.
Posted on Jan 08, 2008
  • 65 Answers
SOURCE: Does this model have a built-in QAM tuner?
Yes it does.
  • Includes built-in ATSC/QAM/NTSC tuner for off-air HDTV and SD (standard-definition) reception
  • Accepts high-definition 1080i, 720p, and 480p signals from DTV set-top receivers and progressive-scan DVD players
  • Side-panel A/V hookups and controls allow easy connection with a camcorder, gaming console, or other device
  • Posted on Aug 15, 2009
    Ematic AT102 How do you program it to receive the cable channels when no cable box is needed?
    Unfortunately, the Ematic AT102 does not have a tuner for cable television. It only has a ATSC (digital over-the-air) tuner. You need to connect it to an TV antenna and then search for channels. Depending on where you live, you may need an external antenna to get sufficient signal strength to receive local channels. See http://www.tvfool.com for signal strength information in your area.
    Older cable signals are NTSC (same as analog over-the-air). Newer digital cable is QAM. (Some channels are broadcast as clear QAM which don't need a cable box with some tuners/TVs.)
    To record your cable, you will need a different type of DVR/set-top box. An old VCR or DVD recorder with an NTSC tuner would work to record analog cable. There are a few ATSC converter boxes that also support clear QAM. This is one of the models: http://www.solidsignal.com/pview.asp?p=CM-7003 .
    I wish that I had better news for you. Other options are available for NTSC, ATSC or QAM tuners. Please add a comment with more information about your cable service if you'd like extra information on these options.
    Feb 23, 2017 | Televison & Video
    Comcast cable has stated that i need a cable box unless i have a tv with a QAM tuner. Does my Emerson LF391EM4 flat screen TV have a QAM tuner?
    Depends on where you get your service. Where I liveon East Coast of US, ya got to have a Comcast box (DTA Digital Transit Adapter) or better) PERIOD. Currently, there are no TV sold in my area that can beat the Comcast system. It may be different where you live.
    Aug 05, 2014 | Emerson Televison & Video
    Activate QAM Tuner
    QAM tuner fault. Contact any service technician to replace it.
    If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
    Jul 28, 2014 | Westinghouse LD-3235 32in LED 720p Flat...
    Need help gettin regular cable running on my old model
    This depends on whether or not you have a digital converter box for the TV. If you don't have one you may only be able to get a small portion of the channels you have available. Unless your TV has a QAM tuner you must get a set top box from your cable company. Even if your set does come with this QAM tuner, you will not be able to use your provider's On Demand or receive any Pay-Per-View and most likely you also would not be able to get any of the perineum channels such as Stars and HBO as these are all encrypted by the cable providers to prevent piracy hence the need to have their equipment.
    Jun 17, 2011 | Televison & Video
    I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
    Hi.
    No, your tv is an older model sdtv with an analog only NTSC tuner.
    Newer model have an ATSC/Qam digital tuner, but not your model.
    This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
    Once in a great while you might even find one that has s-video output, but those usually are expensive.
    I hope this helps you out.
    Feb 08, 2011 | Jensen TS2050J 20" TV
    My Brand New 40" westing
    To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
    Learn more about Clear QAM cable signals:
    http://en.wikipedia.org/wiki/QAM_(television)
    Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
    Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
    I am trying to hook up a digital labs, 19'' lcd tv/dvd combo and when i do the initial channel scan it doesnt pick up anything from the satelite at all, i have hooked them toghther anyway i can think of...
    Most HDTVs have ATSC, QAM and NTSC (analog) tuners. It sounds like yours does not have an NTSC (analog) tuner. QAM tuners only pick up digital cable channels. You may need to switch to your cable company's digital service if your not already on it. Call your cable company for further info
    Dec 26, 2009 | Televison & Video
    Menu feature on pltv-3750 is not functioning on dtv source.
    ATSC is not a cable tuner, it is for antenna only. Qam tuner is for HD cable. If you dont have a QAM tuner you need a cable box.
    Feb 24, 2009 | Protron PLTV-37 37 in. LCD Television
    Do i have a digital television?
    Unless your TV has an internal NTSC/QAM tuner it will require an external digital --> analog converter to receive digital broadcast signals after the analog shutoff date.
    If you have Cable TV, most providers will continue to support analog signals on their wire so you will not require a converter box.
    Jan 20, 2009 | Orion Televison & Video
    Televison & Video Logo
    24 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
