Question about Sony KP-61V90 61" Rear Projection Television
Sony projection tv model kp-61v90
My tv will come on briefly and then shut off immediately and the red light just keep blinking
  • CHEMA Dec 21, 2007
    my tv just blinks 4 times and then pauses and blinks 4 times, there is no picture just black screen, happened overnight . can you help me, it was purchased 5 years ago. thank you
    Sergeant:
    Champion:
  • 375 Answers
Possible power supply or short on the b+ run,check for shorted horiz. o/p tranistor.
Posted on Sep 08, 2007
SOURCE:
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
My sony kp-53v35 keeps immediately shutting itself off
Older model---it should when you try to turn it on have the red light blink for several seconds (set is checking things inside) and if comes on and shuts off that light should blink a specific sequence of blinks----5 blinks and repeat it endlessly---
I have a stupid question: when it first failed did you hear a small pop or smell a faint odor of something burning?
Mar 22, 2012 | Sony KP-53V35 53" Rear Projection...
2001 Sony KP 61V90 61 inch rear projection TV has steady red power/standby light and thus is getting power, but doesn't fully turn on. I've read that this may be a fuse. Suggestions on repair?
Hello. I can help, but please could you tell me how many times the front LED blink?. After connecting and press power, see how many times the LED blink. are you sure the TV model is same as that spelling on your question?. send me your answer and will answer soon. thanks
Aug 14, 2011 | Televison & Video
SONY KP-61V90 tv will not power on, red light in front,
Its 2 times blink error code that shows +B volt supply (+135 volts) is shorted, most probably horizontal output transistor is shorted, replace it.
If you are good in soldering parts in circuit board then take out horizontal transistor, check it, found shorted then replace it with same number.
Horizontal output Transistor Q502 number is 2SD2578 and available in Part Store for $10
Let me know for further query, if any.
Thanks.
Nov 18, 2009 | Sony Televison & Video
Color yokes for KP-53XBR45
1-451-441-11 for the Red and Green tubes
1-451-441-21 for the Blue
Dec 19, 2008 | Sony KP-61V90 61" Rear Projection...
Tv Problem
How many times does the light blink in between pauses? Also is your model the KP-61HS10 ? Please respond to this same post and I should be able to help you.
Jul 01, 2008 | Sony KP-61HS10 61" Rear Projection...
Cant fix my sony KP-53S65
If the TV will not turn on and the red light blinks on the front of the set, it means that the microprocessor has detected a problem in the set and shut the set down. It then blinks the red light a certain number of times, and the number of blinks is the code for why the set has shut off. How many times does the red light blink before repeating?
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-61V90 61" Rear Projection Television Logo
121 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
