Question about GE (PSS26MSRSS) Side by Side Refrigerator
Does my GE fridge model TFX25CRBCWW have a water filter,and if so where is it located?
applianceboy
  • 77 Answers
SOURCE: Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Posted on Sep 26, 2007
  • 74 Answers
SOURCE: water leaks when filter is connected
Does it leak from the back or the front of the appliance ??
Posted on Aug 28, 2008
nnesmith
  • 162 Answers
SOURCE: GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Posted on Jan 19, 2010
MNTECH
  • 1543 Answers
SOURCE: GE Fridge - The water filter bypass plug is stuck
Should just take a quarter turn CCW to remove. You may loose a few drips of water, but the water shuts off automatically when the plug or a filter is removed. A wrench should not be needed to do this.
Posted on Jul 26, 2010
SOURCE: GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
Posted on Feb 15, 2011
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
I cant find the water filter in the ge gss22jet side by side fridge. I have a manual but it says the filter is on the fridge side on the top right. There is a picture of it in the manual as well. However,...
Hmmm, on that model number i searched 4 of my online parts suppiers and not a one of them shows a listing for the filter so despite what the manual says i belive that model does not have a built in water filter
Sep 17, 2011 | GE GSS22JET Side by Side Refrigerator
Fridge is making Ice and will dispense Ice. Fridge will not dispense water at the door.
. Check your water filter first . On some models , only the drinking water is filtered . I don't know which model you have therefore you'll have to check and see if your ice maker water supply is filtered or not . If it is not , that is probably a bad water filter you have . However , if it is , I would check the supply line from the chiller located in the refrigerator compartment usually on the lower right hand side at the back of the compartment . The problem could be a plugged supply line from the chiller to the water valve on the door .
Mar 10, 2011 | GE Refrigerators
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Where is the water filter
Depending on the model, it is inside the fridge.
Some other models the filter is on the bottom grille, twist kind.
Look for your manual or look for those clues
Feb 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
About 15 yr. ol GE Profile
YOU MIGHT NOT HAVE ONE ge started puting factory filters on in 1999 . you might have an inline one in the water line behind the fridge . but only if the homeowner or installer put one in , ge has nothing to do with it .... replacements at any hardware store
Feb 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
WATER FILTER
All of the cabinets I have worked on have had external water filters, so unless yours is really special you will normally find the water filter located behind the fridge freezer in the incoming water supply line (typically 4 - 6 inches long 2 inches diameter). Some cabinets now have a timer to indicate a long duration, none that i have come across monitor water quality. Hope this helps.
Mar 09, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Sep 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
