Question about Watches
Fila watch manual 38-003 - Watches
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
SETTING TIME ON FILA WATCH
how to set the fila38-015-005 watch? any help please. ty
Jun 13, 2012 | Fila 31506 Grand Prix Watch for Men
Need to program a fila silverstone watch
I have a copy of the book for it.
Jan 03, 2012 | Fila Watches
How do i set alarm on fila posdeidon chrono
http://www.poseidonwatches.se/ManualPoseidonClassicAndCrono.pdf
dear click this link and fin the manual hope you will get the solution
thx
Dec 31, 2011 | Watches
Just had a new battery installed in a fila wind master watch. the hr, min and sec hands are spinning and it goes through the start cycle. not able to stop this. also need instructions on how to set time....
Hi, According to your problem first make sure that the battery that you have changed is OK, or try another battery. Your watch need a factory reset. If normal factory reseting doesn't solve your problem then you have to repair the machine.
Jun 29, 2011 | Fila Watches
The manual with the watch doesnt match my watch where can i get the correct manual?
mcdevito75 Here, Contact the maker of your watch as stated in the instruction manual and explain the error manual to them, request the correct manual for your watch.
Sep 02, 2010 | Watches
Do I need to wind a Fila Chronograph Automatic Watch
Under normal use winding an automatic watch is not needed.
If it has been left unused for more than about 3 days, then it will stop. On some automatic watches you can wind them but if yours does not allow this, then, holding it level (face up), swing it gently from side to side for a few minutes. This should wind the watch and after this normal use should be sufficient to keep it wound.
Aug 01, 2010 | Bulova Watch
Watches Logo
135 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
