Question about Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer
Wt-189b high low settings - Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer
I want to remove content control
REMOVAL
A/C Compressor Mounting
1. Discharge the refrigerant. Refer to MTC-111, "HFC-134a (R-134a) Service Procedure" .
2. Remove the front right wheel and tire assembly. Refer to WT-6, "
Rotation" .
3. Remove the engine under cover and the splash shield using power tool.
4. Remove the engine air cleaner and air ducts. Refer to EM-14, "
Removal and Installation" .
5. Remove the drive belt. Refer to EM-12, "
6. Disconnect the compressor electrical connector.
7. Disconnect the high-pressure flexible hose and low-pressure flexible hose from the compressor.
Jun 13, 2014 | Computers & Internet
Hello, I have a stihl hs60/61 hedgetrimmer, with carb wt-189b. My problem is: It can start maybee for 5sec and sometimes I can rev it up. But after it dies and try again it wont start? I have cleaned...
Your plug you say is getting wet so fuel is getting into the cylinder, Maybe its just a fuel air mix preventing it from firing. Screw both the H&L screws in all the way then turn them out anticlockwise to the following settings. H 1 full turn out, L 3/4 of a turn out. This should be set back to standard settings. Also check the fuel line for any holes and also make sure fuel doesnt leak out the fuel tank vent.
Jul 31, 2013 | Garden
Stihl FS 80 carburetor settings for high and low screws
Hi F Del
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Oct 10, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
Car settings stihl 026 with wt 194 carb?
Hi Alan Cowart
Sep 09, 2012 | Stihl 026 Ms260 024 Ms240 Original Walbro...
Wt 194 settings
Hi
Wt 440 zama leaf blower carb settings
Sounds like a fuel problem I would look at getting a new fuel filter. You have the carb set right. That's what I have mine set at.. Good luck
Sep 08, 2012 | Homelite Consumer Products MightyLite...
Stay in high flats 4up low water pressure is there away of reducing the pressure in the hotpoint wt 540 washing machineso it will take in te water
If your water pressure is to high or even to low then just check the taps at back where hoses are fitted. Make sure they are fully open if pressure is to low, also make sure there are no kinks jn the pipes. If pressure is to high then just turn taps down a little.
Mar 12, 2010 | Hotpoint Aquarius WD63 Front Load...
Low beams not working on 2007 dodge ram 1500
a possibility is the multifunction switch or the tipm being bad. check the wt/lg wire in the left headlamp assembly and the wt/tan wire in the right assembly for power
Jan 26, 2009 | 2007 Dodge Ram Truck
Mitsubishi WT-42313 TV
I found the schematic (downloadable PDF) for $7.99 at http://www.completeservicemanuals.com. Cheapest I found and highly recommended.
The blown fuse was due to a fried convergence IC. There are two of these on the high voltage board; they should be replaced together as a matched set. The bad one had gotten so hot I only had to unsolder three pins -- the rest were already loose!
I found the ICs at http://www.electronic-repair-kits.com, also highly recommended. The correct part for the WT-42313 is STK394-250. Make sure you order a pair and they will send you a matched set.
My set is now operating; I just need to clean the optics and do a convergence alignment.
Sep 01, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer Logo
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
