Question about Craftsman Garden
Electric chainsaw Model 358.341190 won't turn on
Chainsaw manual
What model Husqvarna chainsaw?
Jul 21, 2013 | Husqvarna Garden
Electric Chainsaw Oil
2 cycle for AIR COOLED engines.
Jun 19, 2013 | McCulloch Garden
Ozito electric chainsaw oiler won't work
Personally, I would leave the oiler adjustment to a qualified repair shop. If you turn it back to much, it will get even less oil and will starve the chain/bar!!
May 12, 2012 | Garden
Could the tention bar be wornout, if the chain won't stay tight?
Depending on the model of chainsaw you have, I suggest that the bar is not worn out but when you tighten the two nuts on the cover, pay attention to see if the bolts turn as well when you reach the tightest point. It is usually a sign of the bolts, whose heads are embedded in plastic, are probably turning and inside the worn out plastic cover. This will definitely cause the problem you are describing.
May 08, 2012 | Poulan Garden
I have a model 336 Husqvarna chainsaw and it won't start. Put fuel into open plug hole replug, then turn it over it fires until the fuel runs out & won't restart & has full tank, obviously...
There has to be a kink in your fuel line ,or some blockage. Dump the fuel out ,then disconnect the gas line and try to blow air through the line.
Sep 04, 2011 | Garden
Remington electric chainsaw is leaking oil. How
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then clicked search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown"
It may help answer yuor question. RemingtonPower has production and replacement parts are very to find.
I've 7 chainsaws. 6 of them empty the oil tank overnight if I don't empty it. HTH
Lou
Nov 11, 2009 | Remington Electric Chain Saw
The chain-tightening mechanism is broken. The
You can contact Master Distributors to see if they can provide you with the replacement chain tensioner for your particular model electric chainsaw.
Since no model number was provided in your question, I can only redirect you to a site that contains the various models that you can then select from to find the parts breakdown for your chainsaw.
http://www.remingtonchainsaw.com/chainsaw.html
You can also obtain a free manual for your Remington Electric Chainsaw from this site, so save copy for future use and reference, as these are no longer made and you'll be thankful to have a parts list available, should you need to get other parts later on.
You can also give them a call at 1-888-917-2244
I hope you find this Very Helpful and best regards!
Oct 22, 2009 | Remington Electric Chain Saw
Need to know what kind of oil to put in ryobi chainsaw
If it is an electric chainsaw (not gas powered) then the only oil you need is chainsaw bar oil, which lubricates the chain and bar during use (self feeding system). This goes into the chamber at the top of the saw. You can buy chain/bar oil for chainsaws at any good hardware store or outdoor power equipment store. You can use any brand of chain bar oil, most are pretty good.
If it is a gas/petrol operated model, I will need to know the model number to advise on that.
Jul 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chainsaw lubrication
Use regular bar oil available almost everywhere, not motor oil.
Jun 30, 2009 | Electric Chainsaw Sharpener
Garden Logo
131 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
