Question about Frigidaire FD27NKEC (NG) Grill
How to replace burners on the fd27 model - Frigidaire FD27NKEC (NG) Grill
HOW TO CONVERT FROM NATURAL GAS T PROPANE
Their are 2 types of ranges. Ones with sealed burners and ones that do not have sealed burners. The sealed burner ranges must have a kit to replace the orifices. The none seal burner models are simply called crank down and flip models. That means you flip the screw on top of the regulator to where it reads LP. and then you tighten down the spuds on the top burners and the oven valve and then you adjust the air shutters.
Note: Some stoves with sealed burners cannot be converted to LP. The model number you posted is not a correct model number.
Nov 19, 2010 | Kenmore 72002 / 72004 Kitchen Range
I have a Viking Grill model VGBQ530 with cast iron burners that need replacement. I cannot find the exact model no. with these replacement burners however it appears that Viking now have a replacement made...
That is correct. Viking no longer supports the Cast Iron Burners. There is an aftermarket Burner VIKU1 that comes with mounting brackets to convert older Viking Grills that used a Cast Iron Burner to be able to switch to the stainless steel burner. The large bracket attaches to the center tube and has two screw holes and screws for mounting to the rear of the housing. The two smaller brackets mount to the two holes at the rear wall of the housing and create a ledge for the end of the two tubes to rest on.
Jun 11, 2017 | Viking Grilling
Some of the electric burners only work some times. If you wiggle them they will come on and make funny noises, but if you move just right they will go off again. I have replaced the burners but still have...
This sounds more like the receptacle that the burner plugs into is faulty. Remove top and check. In some models this is a common failure. For diagrams of your oven go to www.appliancehelponline.com and enter your model #. Easy to replace on most models.
Mar 21, 2010 | Kenmore Kitchen Ranges
MODEL 720-0061LP How to replace old burners
  1. Turn off gas, and let grill cool.
  2. Remove cooking grates.
  3. Remove heat plates.
  4. The burners are held in place with hairpins. You may need to go beneath the casing to remove these pins.
  5. Pull the burners back and up to remove.
  6. The part number is 26301 from bbqparts.com.
Mar 13, 2010 | Grilling
I need 3 burners for Grand Gourmet Gas Grill Model No. GBC621A-M
Try this link: http://www.grillstuff.com/grill-parts/brinkmann/810-2300-b/?cat=27&brand=5&model=8938
It should bring you right to your specific grill and list replacement parts including burners.
Cheers!
Sep 08, 2009 | Brinkmann 810-2300-B Grill
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
I need to know how to remove the stainless steel burners and replace them.
Call Weber to receive free warrenty burners. Have model and serial number found inside one of the doors on your grill. I just received them in the mail about a week ago and just replaced my burners today. Here is what I did.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Apr 16, 2009 | Ducane 30400042 (LP)
I have Dell Inspiron 5160 laptop. I want ot replace the CD-RW/DVD with a CD burner. What should I be looking for or is it better to go with an external DVD burner?
Well a CD-RW/DVD ROM is a CD burner so you really dont need to replace it. Unless you meant replace it with a DVD burner then...
The best thing you can do is go to the Dell website and search your notebook/model number and look for the upgrade drive and buy it from them. If its to expensive search ebay or the web with the info you found on the Dell website (combo drive name + model number) and find one for a cheaper price.
Jan 04, 2009 | Dell Inspiron 5160 8X DVD+RW, IDE - R5024...
Replacement burners
I could not find your model on new world appliances but here is the website: http://www.newworldappliances.com
call them and ask them where you can get the burners.
Mar 03, 2008 | Kitchen Ranges
Replacing cd/dvd burner in a hp laptop model:dv4030us
I have GSA-T20L, lightscribe DVD burner that I need drivers for.
Please help!
Oct 26, 2007 | SySTOR Systems (400S52) Burner
Frigidaire FD27NKEC (NG) Grill Logo
165 people viewed this question
Top Frigidaire Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Frigidaire Grilling Expert? Answer questions, earn points and help others
