Question about KitchenAid Ovens
Need oven control board 3149045 which is no longer available
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: thermador model scd302t4 double oven,
Welcome to FixYa.
The issue with these displays is they lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to replace the control/display kit...the display only is not available, but a "kit" is.
You can find these "display kits" at "repairclinic.com" and similar to what I've attached here...
**Your other option, and the one I recommend, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
Here you'll find all the info pertaining to this option by clicking on the link I've provided below
http://www.corecentricsolutions.com/CCSWeb.nsf/published/bosch
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Posted on Feb 23, 2011
Where can i buy a replacement control display
Hello Friends!
This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem- This control board is no longer available to buy new. Contact FixYourBoard.com at 512-355-1108 for more information. The photo below is from a double oven, but they repair single oven displays too.
Apr 13, 2017 | DCS Ovens
Control board malfunction
Control board 4452890 (equivalent to: 1057546, 4451856, 4451991, 4452898, 4453664, 8302967) is no-longer-available from Whirlpool. This board can be remanufactured at www.fixyourboard.com. The rebuild comes with a 2 yr warranty. Turn around time is a few days.
Mar 18, 2014 | Whirlpool Ovens
Rbd245pdt12 error code e6 &f2
This oven uses control board part number 8302967. E6 F2 is due to a failure in the control board. This board is no longer available from Whirlpool. It can be rebuild at www.fixyourboar.com with a 2 year warranty.
Apr 01, 2012 | Whirlpool RBD305PD Electric Double Oven
E2 f6
E2 F6 means that your oven temperature sensor has failed as well your electronic control board.
The oven temp sensor, electronic control board and the touchpad must be replaced.
Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Jun 01, 2011 | Whirlpool GBD307PD Electric Double Oven
Model RBD245PDT12 has message error E6 and F2
This is a common failure of the control board. It is often accompanied by a intermittently blank display. The board is no-longer-available but we can rebuild it for you at www.fixyourboard.com.
Control board part number: 8302967
Apr 21, 2011 | Whirlpool RBD245PDS Electric Double Oven
Kenmore dual fuel oven model 79075503201. bottom element in oven will not heat. element has a resistance of about 22 ohms. 110v on each leg while off. 110v on each leg during bake cycle. I suspect the...
It seems that the control board is faulty. You would need to get the board repaired since it is no longer available for purchase from the manufacturer. You get the board fixed from www.partsimple.com at the lowest price compare to the rest of competitors online.
Here is the direct llink to the control board: http://www.partsimple.com/318010102-frg-r-12.html
Frigidaire Range Control Board Repair Service 318010102
Mar 15, 2011 | Kenmore Elite Stainless Steel 40" Dual...
Oven shut off not working
First make sure you have power to the control board. If so, the control board has failed. It is no-longer-available but can be rebuilt by fixyourboard.com.
Aug 01, 2010 | Whirlpool RBS275PD Electric Single Oven
Hi I have a Tappan oven model TGF357CCSF. The clock display andtemperature display is working but it is very dim. I have been told the I need a control panel 316028350 which is no longer available is this...
Hey - That part is available thru AppliancePartsPros online listing is clock/timer.  Part # AP2125110     $203.75   These timers are old-timers anymore. Can be hard to find, and at 200 bucks, make ya think twice. Gas model is probably worth it though.  Either way- it's an electronic clock that has had 120v running through it for 20 yrs or so. Time to replace for sure. Let me know if this info helps-  have more if needed-  Thanks--Ed
Mar 16, 2010 | Ovens
What is an f1 alarm code on a kenmore wall oven model 9114012191
problem has been fixed. thank-you for your help.
Nov 10, 2009 | Ovens
GE Electric Range Model #JBP95A F1 and F7 Error Code
F1 is a common error code indicating a failure of the oven control board (aka ERC or EOC). Often these control boards have been discontinued, "no longer available" or are very expensive. We may be able to help and save you money.
We refurbish oven control boards at www.fixyourboard.com.
Mar 29, 2009 | GE JTP27 Electric Double Oven
Ovens Logo
57 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
