Question about Breville VDF065 Halo Health Fryer
The paddle does not turn - Breville VDF065 Halo Health Fryer
Why won't my paddle turn
My paddle won't turn in my Breadman TR 400. - Fixya
www.fixya.com/support/t20366573-paddle_turn_in_breadman_tr_400
Sep 27, 2013 - Posted on Sep 28, 2013.
Breadman TR850 Plus Bread Maker Paddle turn ... - Fixya
www.fixya.com > ... > Breadman > Breadman TR850 Plus Bread Maker
Paddle won't turn in the breadmaker with any resistance My breadmaker paddle won't turn under pressure. I put all the ingred. in and turn on the machine.
Amazon.com: Customer Reviews: Breadman BK1050S 2 ...
www.amazon.com/Breadman.../B003ZDNKSI
Amazon.com, Inc.Breadman BK1050S 2-Pound Professional Bread Maker with Collapsible ... So thepaddle turns and kneads while it goes in one direction. ... So, while I still love mymachine, I do a lot more bread by hand now. ..... Maybe I got a defective unit... but Iwon't be risking it... sending it back and exchanging for another brand.
Amazon.com: Breadman 34923 breadmaker paddle.: Bread ...
www.amazon.com/Breadman...paddle/.../B0041TMO...
Amazon.com, Inc.
Rating: 3.9 - ‎61 reviews
Turn on 1-Click ordering for this browser .... If I don't scrape down the sides a couple of times during the initial mixing, the loaf won't turn out correctly. ... This paddle fit my Breadman TR520 Programmable Bread Maker for 1-, 1-1/2-, and ...
Jan 01, 2016 | Breadman Bk2000b 2-1/2-pound Bakery Pro...
Is the paddle supposed to spin
Your paddle won't turn. Your silver bucket is the one moving (turning) and not the paddle. It's working like it should. I thought the same before I found the lid (cover).
Jan 11, 2013 | Back to Basics -- Plastic Bucket Ice Cream...
The paddle in my new 1.5 L ice cream maker is not turning - is this normal?
Hello Maryo803,
It is not normal for the paddle not to move in these units. First we have to determine weather the paddle is striped or the gear is stripped. At the bottom of the paddle there is a hole that attaches to the turning gear on the machine. Look and see if it still matches the sprocket in the bottom of the ice cream maker. If it does not still match I would suggest buying a new paddle. You can purchase a new paddle from Cuisinart for $8.00 and here is a link to the page. http://www.cuisinart.com/parts/ice_cream/ice-20.html
However, if it is not the paddle please post back to this thread and I will see if it is worth changing out the bottom gear.
Thank you for choosing FIxYa.com
Justin
Mar 11, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Hi there! I've been using my toastmaster model 1142 bread maker a lot lately like almost every day and it has stopped mixing the dough. Once the dough is dense the motor sounds like its running but the...
Pull the pan out and turn the little paddle with your finger. Is the paddle slipping on the spindle? If yes, then your paddle is worn out. If you move the paddle around and it doesn't slip on the spindle then look to see if the ears on the bottom of the pan are turning too when you move the paddle. If yes, then your problem is further down in the machine. You may have a slipping belt. Those are some of the things you can check.
Nov 07, 2010 | Toastmaster 1142 Bread Maker
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
Dose the paddle inside the pot turn? the pot is turnning but not the paddle.
The paddle is stationary while the pot turns the ice cream to mix the cream.
Jun 30, 2010 | Rival 8804-BL 4 Quart Ice Cream Maker
When plugged in& on cylinder turns but paddle
... as it should
When making ice cream,make sure your ice is crushed fine and you use enough rock salt.
Sep 27, 2009 | Maximatic Elite 4 Quart Ice Cream Maker
Error code
C11A0
Paper holding drive
failure
• The exit paddle home position sensor (PC6) is not turned ON
even after the set period of time has elapsed after the exit
paddle solenoid (SL2) is activated (beginning of paddle
retraction operation).
OFF even after the set period of time has elapsed after the
exit paddle solenoid (SL2) is activated (beginning of paddle
paper-holding operation).
This will probably need parts as the paddle assembly is likely to be broken.
Nov 20, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Paddle fan shakes at high speed. How do i balance?
Generally speaking, all paddle fans shake to some extent but if yours seems excessive, you mave have a bent paddle bracket. Try unbolting ( usually 3 screws per paddle) the blade from the bracket while leaving the bracket attached to the motor.. Then run it up at high speed... If it still rattles a lot, you've got an out of tolerance bracket, if it runs pretty smooth, you can put the paddles back on and try it again. ( sometimes reseating the paddles and making sure the hardware is secure will solve your problem) If it turns out that your paddles are the cause of the problem, you can purchase replacement paddles from Home Depot or other home improvement stores.. Hope that helps...
Aug 14, 2008 | Heating & Cooling
It is the little metal plate that locks the paddle shaft to the big sprocket. the little flat spot is worn away. now where do I get a new one, it is may be worth a penny.
Jul 04, 2008 | Kitchen Appliances - Others
Breville VDF065 Halo Health Fryer Logo
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
