Question about Vacuums
We just got a 3100 handlair, and the air pump is rusted and stuck.
My PowerSteamer PowerBrush Deep Cleaner 1694-W wont spray water
Well what I had to do was replace the pump motor you will have to take it apart and look to see if it has ant rust then look at the pump witch it is a white canister looking thing see if it ceased up and then use 3n1 oil or wd40 on it and work with it tell it is free spinning! Then it will work
May 03, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
When i try to use it on manual the green light will flash then turn off, but works on automatic
The hose button will only work if the hose is unplugged from the side. Sounds like it thinks the hose is still in it. There is a small magnet in the end of the hose. Over time they rust and come apart. Bits may be stuck to sensor where hose clicks in on the side.
May 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
I am looking for a User's Manual for a Brother model XL-3100 Sewing Machine
Go to www.mastersew.com and click on Brother then select your model. xl 3100 I just did it they have it there for sale or pdf. take care and good luck. Andy
Mar 12, 2011 | Vacuums
Continual belt breaking
Have u tried clearing the pump pulley of any excess hair and using sand paper on the motor spindle 2 clear it of any rust or melted rubber from previous belts
Feb 08, 2011 | Kirby G4 Bagged Upright Vacuum
Steam vac is making lots of weired noise
Possible that the water pump is stuck . worn out and making this noise.
It can be due to clogging in the pump that makes it louder.
So remove the pump to check clean and reset.
Sep 09, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Pump fills with air and suction is lost. seems
There is a gasket on the air duct that can move and allow ari to be sucked in. Go to the following site and click "view larger":
http://c.managemyhome.com/mmh/answers/Answers.action#l4q145526
This will open a seperate window showing some pictures, one of which shows the gasket on the air duct. Make sure its seated properly.
Nov 06, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
The Bissel little green proheat unit i have won't spray the cleaning solution anymore
The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
Aug 28, 2009 | Bissell 1425-1 Little Green ProHeat...
I think the pump needs to be replaced in my Bissell little green machine. Some water/solution is being pushed through but not enough to spray only drip, if I hold the machine up high while using it (ie on...
I got my Little Green ProHeat when the product was first unveiled several years ago. Shortly thereafter, the nozzle itself developed a clog in the spray jet. Remove the nozzle from the end of the hose, and with the machine running pull the trigger. If a great amount of solution comes out of the supply hole, then your nozzle is clogged. You can try clearing it with a very thin pin and then rinsing it out.
In about 6 months, my pump would no longer spray solution at all but I could hear the tiny pump still running inside the machine when I would pull the trigger. Remove the tanks, unplug the unit, and look carefully and you will see the few screws holding the unit together. Pull it apart carefully and don't use much force as some of it snaps together and you don't want to break those tabs. Once open, you can find the solution pump, a little fella. The drive shaft on the motor that spins the pump had rusted away completely! Design flaw. In lieu of getting it repaired, I simply started using a spray bottle for my solution application. Several years later and I'm ready to take the time to replace the pump - a very simple process. From the research I've done, the part number for the solution pump is:
Manufacturer's Part Number: 6035029
If you google search "Bissell 6035029 VacPartsWarehouse" without the quotes, you should find your part there for around $9.
Try this direct link to VacPartsWarehouse's website:
VacPartsWarehouse Bissell 1425-2 Little Green ProHeat
Click item #9. It's very simple to install. If you can wield a philips screwdriver, and pay attention to how you've disassembled the unit and then just reverse the steps, you can fix this yourself on the cheap.
Good luck! :)
Dan
May 29, 2009 | Bissell 1400 Little Green Pro Canister...
Bissell Proheat Select 2x won't spray water !!
Mine did the same thing and after a good cleaning of all the tubes and jets i discovered the little pump was rusted and fuzed from water allowed to leak inside.
you can tell this very easily as there will be a rust appearance around the little motor and you wont be able to turn it with your fingers.unfortunately the cost of the pump is prohibitive because you wont be able to replace just the motor and even if you could the problem will only return because of poor engineering design
leave it up to the chinese to screw us again
i will throw the whole thing away and go to made in america.com or some other website and find one made in america where we can gets parts and service.
JOHN:
May 11, 2009 | Vacuums
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
