Question about Miller DYNASTY 350 TIG WELDER w/TIG TORCH 951074
Dynasty 350 will not strike a arc unless the cup is touching the table
2 Suggested Answers
  • 24 Answers
SOURCE: arc starter on sync 350 interferes with equipment
It's the high frequency, ground the case of machine, work lead connection and work table, do not chain grounds together, this will cause a ground loop.
Posted on Sep 18, 2009
How many teaspoons in 200 grams of caster sugar
There is no direct conversion from teaspoons (volume) to grams (weight) unless you know what product you're using.
this site: shows caster sugar 1 cup = 200 grams. or 48 teaspoons.
Baking Conversion Table
Feb 16, 2015 | Computers & Internet
Miller 300D I'm having issues striking an arc even when I have it turned up to 140. Or when welding the rod just sticks in the middle of a pass. Welding structural steel with 7018 1/8 Excalibur rod. Any...
The problem might be with your rods. It sometimes happen that the flux around te metal becomes soft if the rods were kept where there is a lot of moisture. If that is the case you can 'bake' the rods in the oven to dry it our. The flux must have a lower melting poit than the metal rod so that it can make a cup. The edges of the cup keep the rod away from the metal, allowing the arc to jump.
How do you 'strike' an arc? One method is to tick on the metal. A better method is to stike the rod over the metal like you stike a match. This action will give you the 'cup' that you need to start welding.
I hope it helps.
Oct 18, 2013 | Welding Tools
I have a help 12 code on my little dynasty machine, and no manual to tell me what it means, is this a major problem with my machine
On this page enter your serial number and you will be able to download your manual http://www.millerwelds.com/service/ownersmanuals.php In the Dynasty 350 manual I see no "Help 12", there is a 32 and 22. If the Help 12 is only displayed when you push a button, it is saying the combination you have selected is not valid.
Dec 22, 2010 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Everything seems normal but the lamp will not
check lamp door and filters (if you have them). if they are not closed or in all the way, the lamp will not go on. otherwise, the ballast may be bad and needs replacing.
Oct 18, 2009 | Sanyo PLC XU35 Multimedia Projector
My Lincoln SA 200 welder will not rev up when I strike an arc.
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
Sep 17, 2009 | Lincoln Welding Tools
Hobart Ultra Arc 350 3-phase blows breaker in fuse panel
if you have a airgas dealer they carry hobart parts im not sure why you are blowing circut brackers unless they arenot big enough
Aug 17, 2009 | Welding Tools
Arc starter on sync 350 interferes with equipment
Jun 25, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
I NEED TO AIR ARC CAN THIS MACHINE DO THIS AND HOW
hook up to the stick position on the machine - to work + to the stinger hook stinger to the air arc hook up air to the air arc turn welder up to top {350}turn air on at the push button on the air arc & get busy
Apr 09, 2009 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Lost rice measuring cup
http://www.retrevo.com/support/Aroma-ARC-838TC-manual/id/21195bh127/t/2/
You can download the manual. The standard rice measuring cup is 180ml (one cup in the US is approximately 240ml).
Nov 26, 2008 | Aroma ARC-838TC 20-Cup Rice Cooker
Miller DYNASTY 350 TIG WELDER w/TIG TORCH 951074 Logo
44 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
