Sharp photocopier al 2021 simulation mode - Office Equipment & Supplies
  • 2072 Answers
SOURCE: AL-1000 Sharp Photocopier
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Mar 13, 2008
SOURCE: sharp al-1644 photocopier
Usually CH indicates that one of the doors on the copier is not closed properly, if it is a flashing CH then there is no toner cartridge in the copier or the cartridge is of the wrong type for this machine. A lot of toners for this machine look alike but are not the same for the machine.
Posted on May 26, 2008
checkitright
  • 1362 Answers
SOURCE: wHERE CAN i DOWNLOAD A FREE iNSTRUCTION bOOKLET FOR A SHARP PHOTOCOPIER AL - 1552
tr this site you may have to register for free, and the manual is free
http://www.nodevice.com/user_manual/sharp/copier_and_mfp.html
Posted on Oct 01, 2008
goodgold
  • 389 Answers
SOURCE: Sharp AL 1551 CS RSPF not feeding
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Posted on Mar 24, 2009
  • 257 Answers
SOURCE: H 4 FLASHING, MANUAL LOST, AL-1220 Sharp Photocopier
Try to press #, Interrupt, C, Interrupt in that order and enter 14 then press copy key.
Posted on Jan 07, 2010
HOW DO I RESOLVE H - 4 ERROR ON MY AR-5320E SHARP PHOTOCOPYING MACHINE?
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Apr 30, 2015 | Sharp Office Equipment & Supplies
How do i fix the h4 error display in Sharp photocopier - al 1000?
This is a heater error related to the fusing unit. You can try resetting it in maintenance mode. Press #*C*. Use simulation 14 to reset the error
Aug 14, 2014 | Office Equipment & Supplies
How to enter in the simulation mode for a sharp AR-5316 digital photocopier and change the settings
Try pressing #, *, C, *, to get into the simulation mode. To change user settings, try the menu feature. Good luck.
Feb 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
I am getting a flashin L and can't make copies?
L1 = Scanner (reading) feed trouble Scanner (reading)
L3 = Scanner (reading) return trouble Scanner (reading)
Reset method :
* Entering the simulation mode
1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON
(The machine is ready for entry of the main code of simulation.)
2) Main code input by 10-key ? Start key ON
3) Sub code input by 10-key ? Start key ON
The machine enters the selected simulation mode.
Press the start key to start the operation of the selected simulation.
Main Code =(14 Used to cancel the self diag other than U2 trouble.)
Sub code = 0
* Canceling the simulation and returning to the normal mode
1) Press the clear key.
Copy SIM 14
Sep 07, 2010 | Sharp AL 800 Copier
SHARP AL-1644
To enter the serviceman simulation mode, press the keys as follows:
Clear → Density select → Clear→ Density select
To cancel the simulation mode, press the clear key. Then enter code 14 then hit start.
Jul 28, 2009 | Sharp AL 1631 Copier
Mar 23, 2009 | Sharp AL-1551CS Copier
Oct 20, 2008 | Sharp AL-1000 Laser Printer
How I CAN CANCEL CODE U2 in sharp arm451n
This resets the code
Sim 16 sub 0 Used to cancel the self diag "U2" trouble. Cancel Trouble Error
SIMULATIONS
Enter the copy mode and perform the following procedures.
[P] [*] [C] [*] [Main code] [START] [Sub code] [START]
2. Switching the simulation mode
Press [USER SETTING] to return to the code entry screen.
3. Canceling the simulation mode
Press CA key to cancel the simulation mode.
You may need to have a tech look at this.
Hope that helps
Jun 23, 2008 | Sharp Office Equipment & Supplies
Ar5316
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
May 07, 2008 | Sharp AL-1641CS Color Copier
k24674
jasbo
jasbo
