Question about Sdi Technologies iHome iP43 - Clock radio with iPhone / iPod cradle - IP43LVC
My wifes iHome iP43 is not working. It freezes. I replaced the batteries with new ones, and reset it by unplugging it and letting it sit. It will work for a bit, then freeze again. Any ideas?
My iphone 4S all of sudden won't charge on my ihome. It worked the day before and my wife's iphone works. It says device not supported. Any Thoughts?
Either the battery needs changing or the charging circuitry in the phone itself goes bad. As another option, you can try power the device off and wait a few minutes before turning it back on. Hopefully that will reset the phone and it will work afterwork.
Jan 13, 2015 | Cell Phones
Tip
How to Troubleshoot my iHome iP97
<p>You can use your iPod or iPhone to listen to music while traveling. When buying an iPod dock, iHome iP97 like, you can connect your iPod or iPhone and listen to your music through a system of built-in speaker. IP97 to use, connect the bottom of the device at the entrance at the top of the system. If you have technical problems with its iP97, you can resolve to try some troubleshooting steps. <br /> <p><br /> <p>1. Unplug the power cord from the back of the unit and reconnect as the iP97 will not turn on when you press the button "Power". Make sure the other end of this cable is connected correctly. If you still cannot connect, try connecting the cable to another outlet. If it is enabled, the faulty exhaust. <br /> <p><br /> <p>2. Remove your iPod or iPhone from the dock and check the connections on the device and the iP97 to dirt or obstacles to the pier is on but does not respond to the button. Replace the device in the dock. If it still does not respond, remove the device, unplug the power cord to the iP97, open the battery compartment at the bottom of the device and remove the two backup batteries. Let the unit sit for an hour to replace. <br /> <p><br /> <p>3. Open the battery compartment and remove the backup battery when the "Battery Low" error message. This means that the backup batteries are low or empty. Replace the batteries with two new AA batteries and put them back in iP97 using the "+" and "-" symbols printed on the inside. <br /> <p><br /> <p>4. Use the volume buttons on the iP97 to increase the volume when the iPod or iPhone is connected and playing music, but you cannot hear. Adjust the volume on your iPod or iPhone, if you still hear the sound. In order to achieve a comfortable volume level, you have the volume on both devices. <br />
on Aug 05, 2011 | Computers & Internet
My iHome iP43's volume stopped working when i replaced the dead +zero brand batteries with unused energizer brand batteries...what happened
Sorry! we have different skill levels and don't always include the specific problem you have encountered. It means we read your question but may not know the answer.
Aug 27, 2012 | iHome IP43 Desktop Clock Radio - Apple...
My ihome ip87 is on and shows the time and alarm, but the sounds don't work, and i can't listen to the radio or my music.
The same thing happened to me. I just have to unpluged it and removed the back-up batteries from the bottom and let it sit for like five mins. works like a charm now.
Jan 17, 2011 | Audio Players & Recorders
My brand new ihome ip87 just stopped working. It will charge my ipod but it shows no clock and it won't turn on.
Mine is doing the same thing. So I looked it up. And it said to take out your iPod and unplug the ihome then take out the batteries from the ihome and leave it for an hour.. Then it will reset itself.. I just did it and it worked.. I also had to put in new batteries in the ihome
Jan 02, 2011 | Audio Players & Recorders
I accidently washed my ipod...when i looked it up on the internet, a considerable amount of websites say to let it sit. I let it sit but it still won't work. I can get my songs to play on my ihome, but it...
Put it in sunlight for 10 minutes, then try again. You can also try using a hairdryer. The moisture trapped inside needs to dry up before it can work properly. If this does not work then take it to the apple store or continue playing it thru iHome.
Jul 27, 2009 | Apple iPod nano
How cold is too cold for the S730?
Take the camera inside and let it warm up to room temperature. Get another set of brand new batteries. But first take out the batteries and let it sit for an hour. Without any power it can reset itself. The mini cpu inside is thinking its too cold and won't let it come on. After the one hour of sitting, put the new batteries in it and try to power it up. Cold weather can kill a brand new set of batteries in a matter of minutes. You should try not using your camera when its below freezing.
Jan 09, 2009 | Samsung Digimax S730 Digital Camera
Ihome won't play ipod, even after resetting ipod
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
Jun 30, 2008 | Audio Players & Recorders
Sdi Technologies iHome iP43 - Clock radio with iPhone / iPod cradle - IP43LVC Logo
20 people viewed this question
Top Sdi Technologies Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sdi Technologies Audio Player and Recorder Expert? Answer questions, earn points and help others
