Wiring diagram for Brivis Gas Heater "Wombat 20" with Honeywell Ignition module-Continuous Retry
4 Suggested Answers
SOURCE: brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
Posted on Jul 14, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Brivis Wombat ducted heater:
This is most likely the thermocouple. Before you come to the conclusion you have to change it... make sure the mating area at the gas valve is clean. Disconnect the thermocouple mounting nut and clean both the end of the thermoouple and the area where the thermocouple is mated to the gas valve. Additionally make sure the flame passes over at least 1/4 inch or more of the thermocouple probe end. Reposition as necessary to make it rest in the flame. If you have to bend it... do so very slowly and carefully. It is better to bend the bracket vs the thermocuple if possible.
The would be rare but it is possible that you have a very good vent / flue for your heater and the wind is creating a venturi effect that causes too much flue air flow. Maybe 2 times in 40 years I have seen this. It took some careful modifications to the flue cap on the roof by riveting some extra metal pieces on to the cap. (trial and error for over an hour!!!) I seriously doubt this is your problem.
You either have a dirty thermocouple
Dirty thermocouple mating area
Inproperly positioned thermocouple
or.... of course the thermocouple is just slowly failing.
I do NOT think you have a gas valve problem at all.
Thanks for choosing FixYa,
Kelly
My experience: http://blog.fixya.com/index.php/2010/05/award-winning-service
Posted on Jul 03, 2011
  • 81 Answers
SOURCE: Brivis gas heater - Wombat
Take fan apart - easy. Clean with WD40 and then oil with 3and1
Works on all fans.
Posted on Jul 19, 2011
Can we turn the heat off 2-3 rooms with this brivis wombat 92 gas heating system - heating just the parts of the house we choose.
You could freeze water pipes if bathrooms are connected to those rooms - on a cold winter day (depending where you are). All gas appliances should have a shutoff valve. Shutting that off may screw up the main controller - it won't get the proper signal that the flame started ok.
Aug 24, 2014 | Heating & Cooling
Brivis wombat 2P 20
love to know how you went , i have a similar problem with the same unit.....
May 29, 2013 | Heating & Cooling
Brivis buffalo 20 problems
Potentially bad pilot valve. clean pilot. then report back.
Jun 12, 2012 | Heating & Cooling
Brivis gas heater - Wombat 20 - fan doesnt seem to be operating at full speed
Works on all fans.
Jul 15, 2011 | Heating & Cooling
My brivis wombat 120 igniter won't work so I can't light the pilot
I have a brivis wombat 120. When room temperature is lower than required temperature, it starts to fire up and sends heating air. Now, it does start firing. If I increase the temperature testing, you can hear ant click sound from heater, but no firing. Can anyone help
Mar 26, 2011 | Heating & Cooling
Brivis Ducted Heater works Non-stop
When you disconnected the W wire, was the R wire hooked up? If so then you either have a bad tstat or the R and W wires are shorted together.
Jul 23, 2009 | Honeywell Heating & Cooling
Brivis central heating fan will not switch off runs continuous
May 12, 2009 | Heating & Cooling
Honetweel heater control unit failing
you would have to study the wirring diagram etc but any gas heater control should work, you just have to know how to hook it up as the ignition etc is all incorporated in the control
May 03, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
