Question about Cycling
Schwinn Le Tour Tourist 10 speed x-lite Numbers
Schwinn Le Tour Tourist 10 speed x-lite Numbers found on bike 0691 and 60639 any idea when this was made?
  • 1137 Answers
SOURCE: need to know where brake cable goes on an old
Check out www.sheldonbrown.com. There are good pictures and explanations and he has a humorous side to him which makes you feel better about the frustrating side of the problem.
Posted on Jun 25, 2009
  • 921 Answers
SOURCE: How do I operate 10 speed road bike?
the gear lever on the left controls the front derailleur which will have two different size sprockets...when you first start to ride you want it on the smaller of the two. The gear lever on the right controls the back or rear derailleur with a gear cluster of five small to increasing larger sprockets...when first starting to ride you want that on the largest one .....five in the rear and two in the front (5x2=10 variable speeds to chose from). as you increase speed slowly lift up (because this lever will be located down) on the right shifter to help maintain an even speed to help you go faster..when your on the smallest gear in the back and want to go even faster then pull down on the left shifter to go to the larger sprocket you are now in ten gear.When coming to a stop reverse the shift levers and repeat...if the chain rides off the sprockets when shifting especially in the front derailleur it means the shift guide is bent to far to one side or you derailleur needs adjusting same goes for the rear..there are two little screws stops with springs that you use to make these fine adjustments. My family owned a Schwinn shop, i was a mechanic for a good 12 years and i havent heard the name La tour in a long time i owned one myself and have a traveler still today. Tip..keep chain lubed, WD-40 will work fine, and also lube the gear cables with a light grease...also dont rotate the handle bars up for easier comfort because in an emergency stop situation all your weight will transfer to the brake levers and you fly forward over the handle bars.
Posted on Oct 03, 2009
willinois
  • 77 Answers
SOURCE: I found two Schwinn bikes
The Le Tour serial number does not appear to be correct. Please check it as it is probably a AH beginning instead of 4H. If AH it is a 1972 (January). Nice bike with 3 piece cranks. Heavy, but not normally worth much. Expect a value under $200 if in really great shape. The Sports Tourer is definitely from 1972 (December). Also not worth a bunch. Also 3 piece cranks. Heavy steel Frame and fork. Remember that old man Schwinn wanted to keep his business proprietary, so his 27" tires and tubes from that era are a different size then everyone else. Finding "Schwinn Size" tires might be a little tricky and your normal Ace or Walmart may not have them. Also, buying too cheap of tires is not a great idea as often they won't bead well and you ride with humps. Tires alone could set you back over $100.00. Good tune-ups and cleanings could hit you for several hundreds more. If you don't want to put more then they are worth into them I would take off the cranks & seats and sell them on ebay and the rest to the scrap yard. IMO
Posted on Feb 01, 2011
dunnbiker
  • 8546 Answers
SOURCE: LOOKING FOR AN OWNERS MANUAL
I wouldn't hold my breath waiting.
What exactly are you needing instructions for? Most bikes are just static frames with a bunch of aftermarket (Shimano, for example) stuff hung on them.
For unique parts use a search engine. There MAY be something out there.
http://www.schwinnbikes.com/support/owners-manuals
Except for proprietary frames or technologies, everything on a common bike is found on just about any other brand of bike and the individual components are usually documented at the individual manufacturers' websites.
Places like http://www.parktool.com/blog/repair-help document many of the repair and adjustment procedures.
Google will find tons of How-to videos for assembly and adjustment.
Posted on Jun 07, 2011
dunnbiker
  • 8546 Answers
SOURCE: in instructions on
Take it to a search engine and get instant video answers.
"how to re install a derailleur"
Posted on Jul 24, 2011
What year is my schwinn FB08291
Congrats! Your bike is an original Chicago Schwinn.
Built: JUNE of 1966 Search Results
Schwinn serial number lookup tool
schwinncruisers.com/serial-number.html This tool searches a database of Schwinn serial numbers and if it finds a ... box and click "find" to see what date and year your Schwinn bike was manufactured.
Schwinn Serial Numbers and Date Codes - Re-Cycle
re-cycle.com/History/Schwinn/SwnB_Serial.aspx All serial number records before 8/18/1948 were lost in a factory fire. ... If you have a Schwinn from this era, please, PLEASE send us pictures of your bike and serial number (Cutter@Re-Cycle.com). We are in the process of collecting pre-1948 serial numbers in the hopes of rebuilding ...
THE SCHWINN DATE CODES BY YEAR,MONTH AND DAY - Angelfire
www.angelfire.com/rant/allday101/SchwinnCodes1.html/ THIS CHART APPLIES TO CHICAGO SCHWINN`S ONLY. SCROLL DOWN FOR THE DATE CODES LINKS BY FRAME LOCATION OF THE SERIAL NUMBER.
How to Identify a Schwinn Bicycle ' Gone Outdoors ' Your Adventure ...
goneoutdoors.com/identify-schwinn-bicycle-6115826.html Schwinn bicycles are easy to identify by the Schwinn logo displayed on the bike. ... Johnson Outboard Identification ยท What Is the Difference Between a Schwinn ...
Schwinn serial number result
Jun 18, 2017 | Schwinn Cycling
Can you show me a picture of a stem cap bolt and stem clamp bolt for a Schwinn Surburbia 26-inch, 21-speed bike?
Found this with Google - multiple pics of bike: Schwinn Suburbia 21 Speed Bike Current price 105 It would be very helpful in assisting you if you said what problem you are having.
Jun 13, 2017 | Schwinn Cycling
My schwinn 10 speed bike has us patent, with no3477303 how old is my bike please
It's no older than November 1969 which is when that patent was issued. There are a number of Schwinn forums where you might be able match other components to get an idea of when your bike was built.
Jan 27, 2017 | Schwinn Cycling
I have a schwinn serial number dp509984. I would like to known what year make and model it is as well as a price range if at all poossible. Thanks for ur help
It would help if you had at least provided the type of bike (old coaster brake, 3 speed, 10 speed, etc.) The make is Schwinn, the model is written right on the bike frame or chainguard. If the bike is repainted so that the model is not visible it's not worth much. As far as year, just Google "Schwinn serial number" (and note info about date codes) and see my tip for more info: How to determine the year value etc of your bicycle
Nov 05, 2016 | Schwinn Cycling
Date of manufacture of predator serial number 00583 schwinn
That is better, now we have something to go on :>)
http://re-cycle.com/History/Schwinn/SwnB_Serial.aspx
Lots of info
  • Schwinn Serial Numbers and Date Codes - Re-Cycle re-cycle.com/History/Schwinn/SwnB_Serial.aspx Schwinn Serial number and date code ... Schwinn Serial Numbers and Date ... out the crankset to check for a date code. If you have a Schwinn from ...
  • Schwinn Serial Number Info - BMXmuseum.com Forums bmxmuseum.com/forums/viewtopic.php?id=18201
    • LAST UPDATED: 2013-05-10
    • 51 POSTS
    • FIRST POST: 2007-06-28
    Schwinn serial number sequences, ... separate date code number on the right rear fork end that ... I have a 1980 schwinn predator.
  • Schwinn serial number date codes - Angelfire www.angelfire.com/rant/allday101/SchwinnCodes1.html this chart applies to chicago schwinn`s only. scroll down for the date codes links ... if the serial numbers are found on the left rear dropout
  • Determine the Manufacturing Date waterfordbikes.com/w/culture/paramount/paramount-dating Determine the Manufacturing Date. ... Schwinn would add another digit, ... serial number 018524. All Paramount tandem production had ceased by the end of 1979.
  • Schwinn Lightweight Data Book (Serial Numbers) schwinnbikeforum.com/SLDB/serial.htm Serial Numbers Chicago built Schwinn Serial Numbers for the ... a letter representing the month of manufacture, a number indicating the last ... Schwinn Date Codes ...
  • Schwinn serial number lookup tool schwinncruisers.com/serial-number.html Vintage Schwinn serial number lookup. Enter your Schwinn serial number in the box and click "find" to see what date and year your Schwinn ... Schwinn serial numbers ...
  • Bike serial numbers https://bikeindex.org/serials Serial numbers All bikes 1 all have unique serial numbers. Most bicycles have their serial number engraved beneath their bottom bracket, but sometimes serial numbers ...
  • How to Date Schwinn Bicycles ' eHow www.ehow.com > Hobbies, Games & Toys > Hobbies > Antiquing How to Date Schwinn Bicycles. The Schwinn Bicycle Co. is an American bicycle company and a ... For Schwinn's the serial number location has moved to ...
  • Nov 10, 2015 | Schwinn Cycling
    Schwinn bike serial numbers
    The Schwinn Super Le Tours were made in Japan from 1976 to 1985. Your serial number "K6" would have been made in November 1976.
    Jul 18, 2014 | Schwinn Cycling
    How to Tune up Schwinn 10 Speed La Tour
    Take it to your bike shop for correct repairs
    Jun 04, 2014 | Schwinn Cycling
    Bike serial number look up
    Hello. The best thing is go to a bicycile dealer and have them look up Schwinn Serial Numbers.
    Apr 18, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
    LOOKING FOR AN OWNERS MANUAL FOR A 1981 SCHWINN LE TOUR 10 SPEED. THERES GOT TO BE ONE OUT THERE IN CYBER SPACE TO DOWN LOAD.
    Jun 07, 2011 | Schwinn Cycling
    I found two Schwinn bikes in my mom's garage after she had passed away. One was a Schwinn Le tour (light blue) serial # 4H1152 the second was a Schwinn Sports tourer (green) serial # MH623652. Both are not...
    That is a good find!-- I always favor the Schwinn line-- My Dad used to sell them in Warsaw, New York years ago!
    You ask good questions-- and maybe I can give you some thoughts--
    Likely you will need new tires and tubes all the way around--
    You local hardware (maybe even Wallmart?) - or for sure your local bike shop will have them--
    Be sure to take the exact size numbers with you-- for there are MANY SIZES in tires these days!
    Now-- What are you planning on doing with the bicycles?
    The old Schwinn's were Strong, Sturdy AND HEAVY (by today's standards..)
    (I used to Pedal papers for years with my Schwinn Corvette!!)
    Most bicycle riding enthusiasts these days want lighter bikes-- and thinner tires!--
    Great for the long run-- Are you going to use the Bikes yourself, or were you thinking of selling them? -- They probably mean more to you (and are probably worth more to you-- if they were old Family Heirlooms' )
    So-- Any family history associated with them?
    Let us know if we can help you more
    Mack B
    Jan 28, 2011 | Schwinn Cycling
    Cycling Logo
    56 people viewed this question
    Top Cycling Experts
    John Egan
    John Egan
    Are you a Cycling Expert? Answer questions, earn points and help others
