Question about Whirlpool LSR8233J
I have a Whirlpool LSR8233EQO washer. Everything works fine except that at the end of the spin cycle about a pint to a quart of water is added to the drum leaving the clothes on that side of the drum wet. I changed the timer motor when this first started happening but that didn't help.
SOURCE: Washer spin cylcle leaves clothes wet
Mine did the same thing. Solution. I took it back to the store where I got it. Fortunate for me they gave me my money back. Now I am looking for another one. What a nightmare. There is nothing that has a consistently good recommendation except Miele. Where I live they are not available. Well!! We could always go back to the scrub board. je
Posted on Sep 13, 2007
mumma_1
  • 903 Answers
SOURCE: excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Posted on Nov 05, 2008
SOURCE: My washer will not spin or agitate
change the drive coupling.
Posted on Nov 14, 2008
SOURCE: Washer Spins But Clothes Still Wet
I replaced the Clutch Assembly.
Posted on Dec 11, 2008
samson39
  • 32 Answers
SOURCE: Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Posted on Jul 24, 2009
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Water not draining out w/ spin cycle
sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Washer machine model LSR8233EQO want spin
The agitator is loose I believe. Can I repair this myself? If so, how?
Feb 10, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Adds water at the end of the spin cycle
If it is just splashing the water at the end of the cycle and shutting off-timer issue.
Sep 15, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
