Question about JVC HX-Z10 CD Shelf System
Cd shelf i noticed my cd shelf was open when turned off and tryed to close it but its stuck. when i try and use a different tray it starts to read the disc and then reads zero
  • ttingl9988 Jul 22, 2008
    The stereo that I have right is having the same problems.
The hx-z10 mini stereo system is giving me the same problems again.
Posted on Sep 06, 2008
SOURCE:
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
Disc Tray will not open . There are no Cd's in the player. It looked like a tray came loose and before I could keep it open it closed. Now the disc tray door is stuck
The unit will need to be dis assembled and repaired by a technician. One of the plastic gears may be broken or misaligned. If you are mechanically inclined you could attempt the repair yourself but be careful not to loose any of the parts.
May 04, 2010 | Panasonic SC-AK600 CD Shelf System
The tray of cds does not work properly, does not allow the change of disc to disc and stuck
Try pressing repeatedly the eject button while you turn on the unit. If this doesnot work
then it is a mechanically problem in your player .
You need to manually open to take out the cd .
The rubber thread which should be connected to the motor inside the cd player might have moved from its place.
You need to place the rubber thread to proper place.
Also if the belt is slipping, the mech never gets the "drawer closed" signal, and the disk will not spin.
Mar 04, 2009 | Aiwa NSX-A505 CD Shelf System
Fisher CD-RW1000 2-Disc CD-dvd stuck in player
hmmmm.... try to take off the cover of your dvd player and observe it.(if you try my advice, try it in your own risk and with caution) then check the tray maybe there is something got stuck in there and also check the gears, if nothing, a belt just came off. check the motor too, I guess It has 2 switches too. clean them up. and then try to power up.
note:
(keep you fingers away at the power supply section)
Jan 29, 2008 | Fisher CD-RW1000 2-Disc CD Recorder
Cd door won't open
I just bought the same system a week ago and my stereo door is completely broke and the cd peice doesn't eject
Dec 31, 2007 | RCA RS2664 Shelf System
TRAYS ARE JAMMED
hi, there must be a disk previously inserted which has stuck in the tray or something, open the cover and check if anything is preventing the tray from ejecting.. let me knoiw
Dec 28, 2007 | Philips MCM530 CD Shelf System
ERROR, NO DISK
No if the cleaning does not work, you will need to have the unit hooked up to test equipment to check if the laser is bad. It could also be a bad spindle motor if the unit will not spin. good Luck
Mar 14, 2007 | RCA RS2600 CD Shelf System
CD Changer spinning continually
i have the same exact problem with mine. what i did was manually pull open the cd deck, stop the disk carousel from spninning by holding it still, then push the deck closed. the cd deck will no longer work, but at least it stops spinning. the auxiliary works fine and so does the radio.
Feb 07, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
Cd tray jammed
If you turn it off at the mains, wait a few seconds then turn it back on. As soon as you turn the power on, try and press the button for the tray to open. If this dont work, you will have to open up your system and remove this disc yourself. Good luck.
Sep 21, 2006 | Panasonic SC-PM313 Shelf System
CD malfunction
It sounds like you have put a disc in the tray that the system can not read, so it will just keep trying to read the disc over and over again. If you turn everything off by the plug and wait a few mins the whole system should stop. Put the plug back in and as soon as you turn your system on, try and press the disc open key before the lens gets a chance to start reading it again. If this does not work you may just have a disc jammed. So you will have to get someone to check it out for you if you do not understand what you will be doing, because you may do more harm than good to your system. Good luck.
Aug 29, 2006 | Sharp CDES600 5 CD, 240W, Silver, Mini...
JVC HX-Z10 CD Shelf System Logo
219 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
