Huawei e3131 pdu mode - Computers & Internet
How Do I Know that the Huawei S5700 series switch's Fan Operates Normally in Intelligent Mode?
The fans can work in the intelligent mode or forcible mode.
In the intelligent mode, the fans start to operate only when the ambient temperature goes higher than a specified value. In V200R003C00 and later versions, you can run the display fan speed-adjust threshold minus command on the switches that use the intelligent heat dissipation mode to view the temperature thresholds for the fans to start and stop running. The set fan speed-adjust threshold minus command can be used to lower these temperature thresholds.
Intelligent heat dissipation:
Huawei S5700-24TP-SI-AC
Huawei S5700-24TP-SI-DC
Huawei S5700-48TP-SI-AC
Huawei S5700-48TP-SI-DC
Sep 14, 2017 | Huawei Computers & Internet
How Do I Restore the Default VLAN Configuration of an Interface?
We can take S5700-28P-PWR-LI-AC as example.
The default VLAN configuration of an interface involves the default VLAN of the interface and the VLAN that the interface joins. By default, the default VLAN configuration of an interface is as follows:
Access: The default VLAN is VLAN 1, and an access interface joins VLAN 1 in untagged mode.
Trunk: The default VLAN is VLAN 1, and a trunk interface joins VLAN 1 to VLAN 4094 in tagged mode. That is, a trunk interface allows all VLANs.
Hybrid: The default VLAN is VLAN 1, and a hybrid interface joins VLAN 1 in untagged mode.
Dot1q-tunnel: The default VLAN is VLAN 1, and an dot1q-tunnel interface joins VLAN .1
Negotiation-auto or Negotiation-desirable: If the interface is negotiated as an access interface, the default VLAN configuration of the interface is the same as that of the access interface. If the interface is negotiated as a trunk interface, the default VLAN is VLAN 1 and the interface joins VLANs 1 to 4094 in tagged mode. That is, the interface allows all VLANs.
Run the display this include-default ' include link-type command in the interface view to check the link type of the interface, and then perform one of the following configurations to restore the default configuration of the interface.
Restore the default VLAN configuration of an access or dot1q-tunnel interface.
<HUAWEI> system-view
[HUAWEI] interface gigabitethernet 0/0/1
[HUAWEI-GigabitEthernet0/0/1] undo port default vlan
Restore the default VLAN configuration of a trunk interface.
[HUAWEI-GigabitEthernet0/0/1] undo port trunk pvid vlan
[HUAWEI-GigabitEthernet0/0/1] undo port trunk allow-pass vlan all
[HUAWEI-GigabitEthernet0/0/1] port trunk allow-pass vlan 1
Restore the default VLAN configuration of a hybrid interface.
[HUAWEI-GigabitEthernet0/0/1] undo port hybrid pvid vlan
[HUAWEI-GigabitEthernet0/0/1] undo port hybrid vlan all
[HUAWEI-GigabitEthernet0/0/1] port hybrid untagged vlan 1
Restore the default VLAN configuration of the Negotiation-auto or Negotiation-desirable interface.
[HUAWEI-GigabitEthernet0/0/1] port trunk allow-pass vlan all
Jun 28, 2016 | Compex PS2216 16Port 10100Mbps Smart...
Show me the picture how can I put huawei phones in safe mood
To do this, long press your Power button. Then long press on the Power off option. You will then be asked to reboot into safe mode.
When your phone restarts it will not load any Apps allowing you to disable any troublesome ones.
- See more at: http://www.phonetipsandtricks.com/tips/huawei-ascend-mate/how-to-reboot-into-safe-mode-21/#sthash.XufVaXre.dpuf
How do I enter and leave safe mode? When powering on the tablet press and hold the volume down button until the words "Safe mode" appear on the screen, indicating that the tablet has entered safe mode.
To exit safe mode, restart your tablet.
http://download-c.huawei.com/download/downloadCenter?downloadId=66563&version=250940&siteCode=worldwide
Mar 17, 2016 | Huawei Cell Phones
My huawei E3131 doesn't install on my power mac g4 osx what should i do
Honestly.......Buy a new Mac. G4 is way outdated and truly not worth anything these days. Been there and done that. Good luck !
Nov 06, 2015 | Computers & Internet
How do I build seo friendly urls instead of index.php?=page id on my site?
first enable seo friendly urls in the admin area, this will require .htacces on root o your site. edit RewriteRule nd it will be ok. make sure to backup your site just in case of any eventuality
http://esharpdigital.site50.net/index.php/order
Tvhome media3 exe: http://esharpdigital.site50.net/index.php/order/tvhome-media3-download-link
Huawei e303 unlocker: http://esharpdigital.site50.net/index.php/order/huawei-e303-unlocker
Zip2apk: http://esharpdigital.site50.net/index.php/order/zip2apk-v1-0
Huawei e3131 unlocker: http://esharpdigital.site50.net/index.php/order/huawei-e3131-unlocker
Dec 05, 2014 | Computers & Internet
What's needed to have internet anywhere ,asus laptop with w7,64
In order to have internet access anywhere, you need to order this service at a mobile phone company (such as AT&T) and have a USB modem (e.g.Huawei E3131), which they usually give along with the internet service. You then plug the modem with a card inside into your notebook, log in and then you can use the internet through your provider, just like on mobile phones. Wireless connection only allows you to access the internet in the proximity of a wireless router.
Jun 24, 2014 | ASUS U80A (U80A-RSTML05) PC Notebook
Echolink test reports UDP 5188 and UDP 5189 indicates no receive.
In South Africa there are a few USB (HSUPA stick) dongle's (laptop/notebook) modems available where some work and some don't. I use 8ta (Telkom) which doesn't allow access to UDP 5188 and UDP 5189 yet the CellC dongle USB modem, allows access to Echolink. Two different ISP. 8ta use the Huawei Hilink (E3131) dongle where Cellc use HSUPA ZTE Corporation stick. I cannot comment on Vodacom as I do not use their facilities! Something to consider. At least I now have access to Echolink - albeit having to use a different 'modem'.
Aug 19, 2013 | Computers & Internet
Help me with unlock code for Huawei E3131 imei: 862732012264250. Plse
please help me with unlocking code for huawei modem e3131 imie 866539011903937
Sep 14, 2012 | Huawei TMobile Webconnect USB Aircard...
The server shutdown approxmatly every day
if the log says that the shutdown was unexpected, then I'd suspect a power outage at that time. If you're using a managed PDU, check to see if that outlet (or the whole pdu) is set to power cycle. If you have more then one power supply, I'd recommend plugging them into different pdu circuits. If you're pluged in to a UPS, suspect that the UPS is cycling and that there's no UPS management service running. If you're plugged into (yikes) the wall, suspect building power.
Mar 25, 2008 | Dell PowerEdge 1800 Server
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
