Question about RTO Ho Herpa Freightliner Truck Tractor
Fault code TCU 3. Eaton Fuller smart shift 10 speed. What is fault code TCU 3? Please respond to saslives@hotmail.com
Eaton fuller to speed won't stay in reverse
there's an online store www.reliable-store.com where you can get info on all vehicles, heavy equipment, engines right from service instructions, repair instructions, parts info, wiring diagram, torque specs, electrical, fuse diagrams, error/fault codes everything
May 25, 2018 | Cars & Trucks
I have a Easton fuller 13 speed that won't shift side to side
It is a eaton fuller and it sounds like something is between the linkage rods.
Oct 14, 2017 | Cars & Trucks
My eaton fuller transmission wont shift past 5th when it tries to get into 6th gear it just makes a grinding noise
how many gears in this transmission remembering that Eaton make from 5 speeds up to 21 speeds in their range of transmissions
so if you have a 9 speed box and attempt to select 6 gear without using the range change you will be selecting probably first again
Don't assume that everybody knows what box you have so include all make , model year , equipment application in your posts as they are not linked
Sep 08, 2017 | Cars & Trucks
92 honda lx automatic is surging, not shifting right
Can be a few things. 1) Check the shift solenoids on top of the transmission (front). Remove them and clean out the screens. This would mean your transmission fluid is over due for changing. 2) Maybe it's the Vehicle Speed Sensor (VSS), locate and change that. It's on top of the transmission back under the thermostat area. 3) It could be your Transmission Control Unit (TCU). It's under the floor carpet on your passenger side near the firewall. There is a metal plater covering your ECU and your TCU. The TCU is the smaller box. Remove it, open it and look for burnt items. If you're handy you can replace those items. If you are replacing the unit, make sure it is from a known good one and it matches your car exactly, ie: EX, LX, DX, SE, sport shift button present?, etc... on the circuit board.
Below is a picture of the TCU opened up, here are the transmission codes that your car can display if you are inclined to jump the OBD wire plug to get the reading.
TCU Codes:
CODE LIST:
1-Lock-up solenoid 'A' circuit open or shorted.
2-Lock-up solenoid 'B' circuit open or shorted.
3-Throttle Position Sensor circuit open or shorted.
4-Vehicle Speed Sensor open or shorted - No signal from speedometer.
5-Shift Lever Position Switch circuit shorted.
6-Shift Lever Position Switch circuit open.
7-Shift Solenoid 'A' circuit open or shorted.
8-Shift Solenoid 'B' circuit open or shorted.
9-Counter shaft or transmission speed pulse generator open or shorted.
10-Coolant Temperature Sensor open or shorted.
11-Engine RPM (Ignition coil signal) open or shorted.
12-(No code 12 used)
13-Main shaft speed pulse generator open or shorted.
14-Linear (line pressure control) solenoid open or shorted.
15-Kick down switch circuit shorted.
Oct 12, 2013 | 1992 Honda Accord
Transmission wont shift from high side too low side/ fuller 9speed
Have you Checked your Vacuum Line ? This is the most common issue with the High / Low Problems,....
Apr 08, 2013 | Ford "c" Cabover Semi Tractor-disalvo...
1992 honda accord tcu help
The first thing you need done is to have a tranny repair shop scan the "TCM" (not TCU) for fault codes.
Mar 23, 2017 | 1992 Honda Accord
Check engine light came on
What do you mean "can't find code"? If the check engine light is on, there is a fault code stored in your onboard computer - that's the way it works. If you are using a generic OBD code reader, that is most likely the reason you cannot find any codes. You need to use a scanner that has the correct software to access your ENTIRE computer network, not just the "continuous memory" or "generic" side of your computer system.
The window problem is a seperate problem and must be diagnosed accordingly.
Apr 23, 2012 | Daewoo Matiz Cars & Trucks
Intermittent Gearbox Fault
Suggest you get the TCU codes read (Jaguar dealer or well equipped auto box specialist). Suggest you don't go component changing without a believable diagnosis, could be TCU, could be pressure or speed/load sensors, lots of things, many not as expensive as a new TCU!
Jul 15, 2009 | 2001 Jaguar XJ8
Same as above...
your fault code says that the turbine shaft speed sensor (tss) has no signal.on this vehicles each and every sensor is important as they communicate to the ecu threw a can system which in turn communicate to the tcu (transmission) funny things will happen if the line of communication is disrupted pls respond on your findings
Jul 13, 2009 | 2003 Hyundai Tiburon
RTO Ho Herpa Freightliner Truck Tractor Logo
844 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
