Question about Pyle Car Audio & Video
Wiring diagram for Pyle PLWCH12D 12-Inch 1,200-Watt Ultra Slim DVC Subwoofer
zzedly
  • 300 Answers
SOURCE: bridging to 12 inch kicker competition subs to my 1000 watt alpine 4 channel amp
I'm a bit confused. For Alpine amps, the "M" prefix is for monoblock (aka single channel) amps and the "F" prefix is for multichannel amps. The only M550 I find is an MRD-M550, which is a monoblock, not a 4 channel like you say.
Unfortunately, I can't give you accurate help until we know weather it's truly 1 channel or 4 channel. Then I'll be glad to help!
Posted on Mar 07, 2008
SOURCE: 4ohm subwoofer and 2ohm amp
just run str8 pos and negative
Posted on Mar 09, 2008
SOURCE: 12 inch insignia subwoofers model # ns-sub12
how to wire 12 inch insignia sub woofers
Posted on Apr 13, 2008
  • 24 Answers
SOURCE: Correct Amount of Power needed for my subwoofer
1000 watt or bigger
you always wanna have a little play room with the amp so it wont blow or short out.
also if you do decide to add another sub....the amp will still be able to push both subs..
yeah so at least 1000 would be perfect but if you dont have the money about a 500watt would still push it hard.
just make sure you have all of the options on the amp tuned to make it sound the best and make sure you have the right enclosure for your car. 500 would do...but 1000 would be best =)
Posted on Nov 16, 2008
  • 26 Answers
SOURCE: how to wire my kicker solar baric
All depends on your amp. Is it 1 ohm stable or not?
Parralell:
positive (pos) on voice coil 1 (vc1) to Pos on vc2 and negative (neg) on vc1 to neg on vc2. Then speaker wire from amp to one vc only = 1ohm load.
Series:
Pos from amp to Pos on vc1. Neg of vc1 to Pos of vc2. Neg of vc2 to amp = 4 ohm load.
Posted on Jan 21, 2009
Need wiring diagram for plwch12d subwoofer
We do not have wiring diagrams here at fixya. Sorry.
Apr 06, 2012 | 1999 Chevrolet K1500
I have an AR s112ps subwoofer. I woofer is blown and i would like to find a replacement woofer. I havent had any luck looking on the net so far. any ideas?
all you need is an 8 ohm subwoofer or a Dual Voice Coil (DVC) 4 ohm subwoofer wired in series that can handle 120 Watts rms. I Went with a Rockford Fosgate Punch P1 P1S812 12-Inch 150-Watt Subwoofer - 8 Ohm
it was only $35 from amazon and is probably nicer quality than the original driver. Good Luck
Dec 24, 2010 | Audio Players & Recorders
Cannot get pyle driver 413 bridgable mosfet1000 watt amp to work with 800 watt subwoofer . followed instructions all the lights are lit but no sound need help
just wondering how you connected the amp . you should do the following steps
1 battery cable with right size fuse at battery
2 remote wire from radio
3 rca cable from audio out from radio
4 ground the amp to a good clean piece of metal
then make connection on the amp
1 battery or power cable to the 12volt connector on the amp
2 remote wire to b+ or rem on the amp
3 rca cabel should be pluged in the channels are using cause you tell me that the amp is 4 channel
from the model numbers
4 clean and scrape off paint on the metal surface you are going to install the ground cable from the amp . make sure your ground is no more than 12 inch max. and is the same gauge as the power cable
5 . run your speaker wires to the amp and make sure your ohm load for the subwoofer is 2 ohms or 4 ohms to make the amp work proper .
if need help on anything email me @ caraduioquestion@gmail.com
Oct 29, 2010 | Pyle Car Audio & Video
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
Wiring diagram for dual voicecoil subwoofer
To wire a DVC subwoofer, treat it (in the diagrams) as two seperate speakers, called coil one and coil two. This makes things easier.
To wire them up, wiring them in series would be safer, but if the amp is 2 ohm stable, put them in parallel. Look up dual voice coil wiring in google imagesfor more information and pictures.
Jan 22, 2010 | Soundstream PCS-12 Car Subwoofer
I have a pyle blue wave 12inch 800w subwoofer for a car hook up?
that just means it is dual channel.
if you have a stereo amp just run the left wire to one terminal and the right wire to the other terminal.
if your amp is mono run the wires to the first terminal and then from there to the second set of terminals.
PLEASE NOTE that by doing that you are bridging the speaker if the speaker was 4ohms to start with you just dropped it to 2 ohms so make sure your amp can handle that.
Dec 24, 2009 | Pyle 12" Molded Blue Cone High Power...
What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
TS-W307D2
Design and Specifications
12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
Nov 23, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car Audio & Video Logo
188 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
