Question about Electric Bicycle Motor, Bike,electric Bicycles ,kits
I have an Giant Lafree Twist Model year 2002. The battery is loaded, but still the motor is not answering whem I'm using the powe contro switch! So I cannot use the bike for the way it is made. Where can I find somebody to repair this problem? gilbert.deblaere@skynet.be
3 Suggested Answers
SOURCE: I was given a Giant Lafree electric bike, but it
this one from thailand by engineergirl . i luv it , so cute and stronger and easy to maintainance and... so lovely colour bike
how can i get it because i never know any about electric & electronics at all
http://www.vigothailand.com/board/index.php?topic=98998.0
Posted on Oct 29, 2010
  • 23 Answers
Giant LAFREE TWIST Model Year 2002 Owners Manual can be downloaded from here http://fitness.manualsonline.com/manuals/mfg/giant/lafree_twist_model_year_2002.html
The Sports 2000 model manual can be download from the bottom of this page http://www.manualsonline.com/ex/thread/view/idThread/274867
Another source of info here including links to manual and manuafacturer http://www.batee.com/projects/offgrid/ebike/lafree/index.shtml
Forum on pedelecs with discussion on LaFree http://www.pedelecs.co.uk/forum/electric-bicycles/239-giant-lafree-twist-electrical-breakdown.html
Hope this helps
Posted on Apr 07, 2011
Charger model NC-SSCO4GNT. Can this charger be plugged into 120 or 240 volts to charge the battery?
yes it can be plugged in to a 120 or 240 ac socket but I would like to see the plug end to make a better decision on which one to plug it in to
Mar 07, 2016 | Giant Twist Express Womens 2011 - electric...
Have a husqvarna generator 1365 GN. Model 01935. The engine runs but it does not produce electricity. The auto idle quit also. I've replaced the brushes and rectifier, but still no electricity.
A bridge rectifier is not realy something that is broken but the voltage regulator moduul in the electric field thats also by the capacitor to find, this electronica can be defect or its that capacitor in priority is that not shorted ?? take an multimeter and look if its loading from the meter switch the poles to see if its going load up and down. if its shorted take a sound measure check for shure if you twist the poles it has only one resistance value, then change capacitor , if its not the capacitor but the voltage regulator modul then make a note of your motor number with all things about the building year to prevent for a disappointment if you get a wrong model if you give no details of the motor because of the modifications by years or model with other motors.
Feb 17, 2016 | Electrical Supplies
I am having an electrical problem with my 2002 GMC HD2500 Dura Max diesel.....did not crank at all this morning. Both batteries were 4+ years old. Figuring it was the batteries, I just went ahead and...
Starter relay , ignition switch , park neutral psition switch if automatic trans , clutch start switch if manual trans. , battery cables ,connections . If you don't know how to do automotive electrical circuit testing , your best bet , take it to a qualified repair . How to voltage drop test starter motor circuit
Starter Voltage Drop
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter the vehicle info. year ,make , model and engine size . Under system click on engine ,then under subsystem click on starting . Click the search button ,then the blue link . Look an see what all is involved in the starting system . Use a volt meter an test to see where B+ voltage is an where it isn't while someone turns the key to start . You can rule out the load (starter ) side by jumping pins 30 & 87 where the relay plugs into . Watch this video on relays .
VEHICLE RELAYS Operation Diagnosis
Jul 25, 2017 | 2002 GMC Sierra 2500HD
My 2002 Sable has a total of 25000 miles. It has been in storage for the past seven years, with only 3000 miles contributed during that period. I am not able to start it now. Apparently battery is...
a battery is only good for 5 yrs, if its used every day. id assume you need a good hot battery because yours does not have the cold cranking amps to turn the car over. have it tested at autozone. if thats not the issue , then the motor is locked up from not being used. seized
Jul 31, 2010 | 2002 Mercury Sable
My XB-300Li motor cuts out after riding about a mile or so
Sounds like overheating alright. How is the weather? If its over 80 it might only be that. If it is cooler, then if you are running the recommended volt/amp battery pack you may have a bad temp sensor on your control board. If you are using a higher powered battery to boost speed then you will have to cool the motor or get a more powerful one that can take the load. I do not have that mode bikel, so I can not say if it is a common problem, It is not a problem with my 24 volt Lafree.
Jul 10, 2010 | Electric X-Treme XB-300Li High Performance...
My 2002 lancer battery keeps dieng but starts whem i jump it but when i kill it tha battery dies any answer what the problem is
If the car runs everytime you jump it & continues to run until you shut the engine down & won't restart, then it is either a bad battery, or bad connections from the battery to the starter solenoid & fuse box. If the ground connection were bad your car wouldn't start when jumped & it's apparent that once you get enough voltage(jumping it) to the cars starting system it will run, there are no other options. Battery or wiring.
Good luck
Jan 27, 2010 | 2002 Mitsubishi Lancer
LaFree Sport Problem - Beeps Twice and LED's Flashing
the matter of beeping is not so serious than the flashing of those LED's every second just get the fuse and the circuit board checked its no self work
Sep 09, 2009 | Electric Bicycle Motor, Bike,electric...
Giant lafree electric bike
I have been riding my Lafree for over 10 years with no such problem. The only thing that comes to mind that would cause such a problem is a loose electrical connection or short, probably at the motor since the battery has a locked connection, and if it were in the control circuit the warning diagnostics would detect it and beep a warning, and probably shut down.
Jul 11, 2009 | Electric Cycling
Trutech PVS21175S1 17" Flat Panel LCD TV
I HAVE THE VERY SAME PROBLEM!!!  HAS ANYONE FOUND AN ANSWER TO THIS PROBLEM???
THANKS LOADS!!!
May 25, 2008 | TruTech PVS31170S1W 17 in. LCD Television
Electric Bicycle Motor, Bike,electric Bicycles ,kits Logo
100 people viewed this question
Top Electric Cycling Experts
Colin Stickland
Colin Stickland
Michial Gueffroy
Are you an Electric Cycling Expert? Answer questions, earn points and help others
