Question about Refrigerators
GE SIDE BY SIDE FRIDGE FREEZER
THIS FRIDGE FREEZER IS ALL MESSED UP.THE FREEZER SIDE IS ONLY COLD ENOUGH TO USE AS A FRIDGE AND THE FRIDGE SECTION IS NOT COLD AT ALL.THE MODEL IS GSG25 MIPAFBB.ANOTHER THING,WE NEVER GOT THE ICE AND WATER DISPENSER PLUMBED UP AND IF WE PLUG IN THE FRIDGE IT BEEPS....ANY HELP WOULD BE GR8 AS IT HAS BEEN STANDING IDLE.
  • 6 more comments
  • shnnrc Sep 01, 2007
    THE BUTTONS YOU PRESS TO DISPENSE THE ICE HAD BEEN BEEPING FOR AGES BUT NOW HAS STOPPED.THE FAN AT THE BASE OF THE BACK OF FRIDGE IS BLOWING.THE BOTTOM SHELVES OF THE FREEZER WILL FREEZE THE TOP SHELVES WILL ONLY MAKE ITEMS COLD AND THE FRIDGE PART IS NOT COLD AT ALL.IT SEEMS THAT THE COLDNESS IS NOT BEING DISTRIBUTED AROUND THE FRIDGE...DOES THAT MAKE SENSE??
    OH AND THERE IS NO FROST AT BACK WALL ANY HELP WOULD BE GREAT.THX
    hI i JUST REMOVED THE BACK PANEL AND THE WHITE FREEZER FAN IS NOT WORKING!
    ALSO THE EVAPORATOR IS FROZEN OVER..
  • Anonymous Mar 26, 2008
    thick frost at back wall of freezer; top shelves in both freezer & food won't cool; very cold in freezer bottom; I have a side-by-side GE GSS22JFMD Refrigerator 6 yr old. How do I fix this? Thank you.
  • briguys51 Mar 29, 2008
    GE side by side keeps freezing over behind rear panel both fridge and freezer start to get less cold.
  • carlos jackson Sep 29, 2008
    I have a frigidire counter depth side by side and the freezer is the same temp as the fridge. the avg temp is 47f. What can I do to resolve this issue. P.S. I am located in Houston and our power has just been restored. We been without power for 14 days.
  • Anonymous Mar 30, 2014
    Model ktrp18kdwh07
The unit is not defrosting because it needs one of three parts that make the evaporator defrost every about 8 to 10 hours depending on the refrigerator, 1. defrost thermostat which snaps on the evaporator coil behind the rear panel in the freezer, 2. defrost heater which is also behind the rear panel in the freezer, the heater melts the frost on evaporator, 3. defrost timer or defrost control which is either on the back of the fridge behind a small panel that must be removed to access to the control or it's in the fresh food section.
Posted on Oct 31, 2008
  • 291 Answers
Need more info on this whats is beeping? do you have any error codes, when is was plugged in... was ALL the fans blowing.. freezer fan and fan below by compressor? was there any frost on the back wall of freezer?
Posted on Sep 01, 2007
  • Mike Johnson
    Mike Johnson Sep 02, 2007
    sounds like u have a fan motor problem
    not sure if just froze up because of frost..you need to defrost with hair dryer.. with fan not blowing that might be your only problem.. evap will freeze up with out fan blowing... also if theres problem with defrost system evap. will freeze up Try defrosting and see if fan will come on. If not you may have to replace, trying to upload a diagram that may help
  • Mike Johnson
    here is a break down that may help you ...wont let me upload... but heres a link not sure if it will work...
    http://www3.sears.com/imaging/ImagePageJ...
SOURCE:
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
GSL22JFRE BS Freezer OK but not Fridge ??
Clean the condenser grille, rear and under unit
Apr 24, 2012 | GE GSL22JFR Side by Side Refrigerator
I have a GE GSS25LGMF side x side refrigerator. The compressor never shuts off and everything in the fridge section is freezing. Is this a thermostat problem?
it could be the damper part number WR49X10091,if the damper door isn't closing correctly cold air will just keep coming into the fridge side from the freezer,usually the damper door opens to let the cold air in when the fridge starts warming up and when it gets cold enough the door will close but your damper is stuck open
Nov 25, 2009 | GE GSS25LGM Side by Side Refrigerator
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
1,169 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
