Question about Baxter Ovens
Baxter oven not rotating - Baxter Ovens
2 Suggested Answers
SOURCE: My baxter rotating tray oven is not baking cookies
Inside your oven you have an array of louvers or fins in the back left corner and the front right corner. Sometimes a tray will jam and knock one of the louvers out of adjustment. You may need to call a local authorized service provider to come and reset your louvers to the factory settings. In the meantime you can attempt to make small adjustments to see if you can rectify the issue.
Do not ever adjust the louvers in the back left corner of the oven.
For the trays in question, to direct more air towards the center of the cookie sheet slightly bend the louvers in the front right backwards towards the rear of the oven. ONLY MAKE SLIGHT ADJUSTMENTS!! If you bend the louvers too far you will end up burning the center of the cookie sheet and under cooking the edges.
Posted on Dec 30, 2011
I need wiring digram for baxter oven ov300e
Request the wiring diagram directly from Baxter.
Feb 23, 2017 | Baxter Ovens
Baxter oven not working
Hobart owns Baxter. You'll have to call Hobart.
Feb 14, 2014 | Baxter Ovens
I have a Baxter oven OV210G, When the door is open the rack will not stop or lower. The micro switches all work and relays seem to work but I can't find the MR3 cantactor and don't if that is the problem...
When you open the door check to see if your burner and circulation fan remain on, if they do you have an issue with your door switch.
Also if your rotation micro-switch was bad you would get a buzzer every 1 second because the oven would think the carrier isn't rotating.
It's hard to troubleshoot beyond that without seeing the oven, its possible you could have a bad relay on your control board. In this case I would call an authorized service provider to have to check the oven out.
Dec 07, 2010 | Baxter BXA2G Stainless Steel Gas Single...
The rack inside has stopped rotating
On top of the oven is a cover with 6 screws in it, loosen the screws and remove the cover. You will see two pulleys, most likely one of the pulleys are loose, try tightening the set screws, the one on the right can be tricky because the set screw is under the pulley. Good luck!
Dec 04, 2010 | Baxter OV300E Stainless Steel Electric...
My baxter rotating tray oven is not baking cookies evenly. The cookies on the outside of the cookie sheet are over-done and the cookies in the middle of the cookie sheet are not done ??
Jun 14, 2010 | Baxter OV300E Stainless Steel Electric...
Ovens Logo
20 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
joneable
Level 1 Expert
Jerry Kramer
Jerry Kramer
Are you a Baxter Oven Expert? Answer questions, earn points and help others
